12-03-2004, 10:01 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 45
Member: 60701 Status: Offline Sonork: 100.1623285 Thanks Meter: 121 | problem to flash with dctx_13 but i can unlock,,,,, i can see mobile info i have a ufs-2 if one can help me please,,,,, i can flash with dctx_12i |
12-04-2004, 19:47 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | 1) check the flash file location. (C:\Program Files\Nokia\Phoenix\Products) if it's correct, then i have this problem too I can unlock Nokia 1100,3100 but can't flash them with my box, i didn't check old suite, just checked with 1.3 |
12-06-2004, 19:17 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | @ali42 need more detail. a screen shot will be good. maybe i can help. check this first: you,re using UFS-2 box and dct-x v.12i. I think, you must update it first into dctx 12m. Which this update need a special file which it's called FBI file. and this file you can get from your reseller only. after that al steps,... if you want to use v13, it need string activation code which available @ support area. let me guess.. do you got "auth error message" when try to flash? regards, may help |
problem to flash BB5 with usb cable | bezz | Universalbox | 0 | 05-30-2008 20:22 |
Problem to flash KG800 with LGM2 V1.0.0.1774 | preshaust | FuriousGold | 3 | 01-15-2008 09:53 |
problem to flash with phoenix soft | Mehvishal | Nokia Base Band 5 ( BB-5 ) | 1 | 07-06-2007 08:22 |
Problem to Flash E710 with Twister! | Maurone | Twisterflasher | 3 | 02-17-2005 11:16 |
problem to flash SE t68i with griffin | GYZMO | Griffin | 5 | 09-05-2004 02:55 |
