10-14-2005, 12:59 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: in the line of fire..
Member: 157118 Status: Offline Thanks Meter: 156 | d500 flash HWK UFS 3 failed have some promlem flashing TFS File to D500. When i reached 50% the thing fails.Can someone help me..the readout. TFS File: d500bvdk8_hw28.tfs CheckSum: EF2E55A6 CFG File: d500bvdk8_hw28.cfg 27804 byte(s) Preloader Ok, 921600 Baud Flashloader Ok FLASH Id: 00EC22FC00010001, Samsung KBJ10KB00M NAND Format Complete, Time: 00:09 File CRC: 0xF18BB433 TFS Version : TFS4.0_CORONA_01 Directories : 55 Max_Files : 380 Directory : /sounds Directory : /sounds/default Directory : /images Directory : /images/shortcut Directory : /images/streaming File: /java/_single8.png, Size: 1069 File: /java/_suite_8.png, Size: 1066 File: /java/_policy.txt, Size: 1033 File: /java/_main.ks, Size: 2164 File: /java/suites.utf, Size: 123 File: /multimedia/videos/downloaded videos/Everything_we_do-a_Funky_Nashiville.3gp, Size: 8149603 File_Write Failed 2 Warning, More Files Found than Specified in CFG File TFS Write Failed, at: 0x018E649F.. if anyone can help.. most apprecated.thanks |
10-14-2005, 14:08 | #2 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Be Age: 48
Member: 3081 Status: Offline Thanks Meter: 8 | First of all, why did you flashed that phone? Was the phone working before?We need more details otherwise we can't help you. You can also have a corupt flash file, try another one. I never used Twister, or ufs for flasing samsung phones. Try this flasher i've uploded here |
10-14-2005, 14:33 | #3 (permalink) | |
Member: 157118 Status: Offline Thanks Meter: 156 | Quote:
I HAVE SUCESSFULLY FLASHED D500 WITH SAME COMBO,I FLASH TFS THEN MCU WITH GREAT RESULTS BUT 2DAY HAVING PROBLEMO. PLEASE SHED ONE LIGHT ON IT PLEASE THANKS.... | |
10-14-2005, 16:16 | #4 (permalink) |
No Life Poster Join Date: Sep 2003 Location: INDIA
Member: 38103 Status: Offline Sonork: 100.100782 Thanks Meter: 165 | Change flash files you selected earlier. Do it without battery - if you have already done it without battery then.. u must open the phone and clean it up carefully. Remove button cell and put it back. regards |
Nokia 3230 is suddenly switched off efen after flashing with UFS-3+HWK | amit123 | Nokia Hardware & Hardware Repair | 3 | 04-20-2009 11:53 |
hwk ufs 3 ufs 4 modul hwk helpp raskal | ceptel | Twisterflasher | 0 | 05-28-2006 17:17 |
AFTER i FLASHED NEW FLASH TO MY PHONE d500 BY TORNADO hwk ufs-3 | ala3sam | SWIFT Platform | 2 | 05-05-2006 21:57 |
Help I need to remove Network lock on a LG U8138 with HWK UFS-3 | mphillips11 | UFS2 + UFS3-Tornadoflasher | 0 | 12-05-2005 20:35 |
Unlocking LG U8138 with HWK UFS-3 | mphillips11 | LG | 0 | 12-05-2005 04:51 |
