Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > UFS2 + UFS3-Tornadoflasher
Old 06-15-2006, 16:32   #1 (permalink)
farrukh mobiles's Avatar
Member: 202298
Thanks Meter: 35
Nokia 1110 menu problem after flash....
Hi dear,
i have Nokia 1110 menu style problem after flash. Now menu show top to bottom and not good graphics. i want original menu style (Right to left or left to right) after flash. any one help me to solve this problem.
B.R
farrukh mobiles
Old 06-15-2006, 16:55   #2 (permalink)
XisiX's Avatar
Member: 37090
Thanks Meter: 42
Did you tried full factory defaults?
(Keep in mind that you'll loose phone book)
Old 06-20-2006, 11:44   #3 (permalink)
Member: 202298
Thanks Meter: 35
Yes but nothing.
I change flash file to 4.04 but nothing.
I am so confused.
any solution??????????????????
B.R
farrukh mobiles
Old 06-22-2006, 06:55   #4 (permalink)
nomi's Avatar
Member: 78440
Thanks Meter: 56
Originally Posted by farrukh mobiles
Yes but nothing.
I am so confused.
B.R
farrukh mobiles
u can flash with griffin flash file ve#3.42 and then 4.04 your problam is solved 100% tested by me many time
Old 06-24-2006, 06:11   #5 (permalink)
Member: 202298
Thanks Meter: 35
Thanks for reply .
but i have not griffin flasher.
any ufsx solution???????????????
B.R
farrukh mobiles
Old 06-24-2006, 07:24   #6 (permalink)
mobiletear's Avatar
Member: 69838
Thanks Meter: 7
hi
any one have any link for 1110 new version5.03 and 1600 same version 5.03 plz help me
Old 06-24-2006, 07:30   #7 (permalink)
nomi's Avatar
Member: 78440
Thanks Meter: 56
Thanks for reply .
B.R
farrukh mobiles
ok. flash with ufs. erase flash then flash mcu file (rh70_04.040) and ppm (rh700_nai4.04mi) then flash only ppm with (rh700_nai3.42aa_demo_1) your problam is solv
bestregard
Old 06-24-2006, 08:51   #8 (permalink)
Member: 260519
Thanks Meter: 46
hi
this problem is you are no flash cnt file.
you need flash mcu,ppm and CNT also.
Old 06-24-2006, 09:23   #9 (permalink)
Luc+Luc's Avatar
Member: 85694
Thanks Meter: 48
Yes. Only problem is with cnt. I tried many times. If you select wrong cnt, graphics on display not showing well
Old 06-24-2006, 09:28   #10 (permalink)
Member: 253021
Sonork: 1585469
Thanks Meter: 75
so br try it with MT-Box , u never faced cnt
Old 06-24-2006, 14:14   #11 (permalink)
Member: 101577
i have the solution and i will post it tomorrow, i'v flashed 3 1110 and evrything is allright. you have to full flash it normally, after you only flash the ppm with the file file that i will upload it... good luck ;-)
Old 06-24-2006, 19:50   #12 (permalink)
asmodi's Avatar
Member: 183976
Thanks Meter: 134
Erase and use and flash all mcu+ppm+cnt
Do a full erase and flash all MCU+PPM+CNT that's work for me all times .
Old 06-24-2006, 20:57   #13 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,395
if you try to flash your phone 3.42 and full factory default... it will help you i am sure...
Old 06-25-2006, 07:01   #14 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 136
Just try different CNT, that's it for sure....
Old 06-25-2006, 17:26   #15 (permalink)
Member: 202298
Thanks Meter: 35
Thanks my dear problem solved here is logooooooo...
100% working & tested solution for 1110 contrast problem after flash. nishaon J.A.F. By Jafsupport.com 1 09-25-2007 13:32
1110 display problem after flashing!!! ionelka Twisterflasher 14 07-20-2006 13:04
Nokia 1110 no network after flash Ntinos69 Nokia Digital Core Technology 4 ( DCT-4 ) 10 03-19-2006 09:24
Nokia 7650 Same Problem After Flash S.SHANTHIKUMAR Griffin 1 07-17-2005 20:21
Nokia 6600 Bluettoh Problem After Flashing With Twister jkgohil WD2 & APE (Symbian Phones) 3 12-23-2004 12:49
Page generated in 0.50613 seconds with 10 queries
