Not able to use rpl-file! Please help! @legija @ufs2flasher Hi everyone I just got an RPL-file which I need to repair Imei-area in a Nokia 6200. Is has been made by ask-file and the converted to rpl-file. When I try to use the write UEM - SL function the program respons by: Ambiguous ASIC TYPE og non GSM-product. Would you like to proceed? Yes or no? What is that? In display window it says: IMEI: ??????-??-??????-?, ASIC: 2 File Info: IMEI=351461500***** CHECKSUM=-2085 No Data2 in File ASIC Type Mismatch, Process Aborted No SIM_PROG_DATA in File What to do? I haven’t tried saying yes. As I understand you only have one try at flashing the UEM chip! Am I right? Is it perhaps because the rpl-file was calculated as ASIC 5 instead of ASIC 2 (Nokia 6200 is Asic 2)??????? Any help would be greatly appreciated :) Thanks in advance best regards Martin |
Is there no one who can help or at least point me i the right direction?? Please!! :) |
Please help. I got a customer waiting - and he wants his phone back alive. Thanks in advance Best regards Martin |
2 Attachment(s) I have this problem also on my nk1100,have u solve it?if yes pls let me know the solutions.thx best regards |
Ok who is doing your RPL calculations for you. maybe thay are not converting it correctly remember griffin server RPL,s are not compatable with UFSX series flashers so you might have needed to covert them to this platform as well and the convertor needs some tweaking to make it work correctly |
The griffin server rpl's not same as original,the severs rpl dont have precalculated simlock data,only data1 and data2 section,and the ufsx series not directly calculated the simlock data,only using map files.Griffin rpl's work with ONLY griffin box |
Wher we found RPL calculations for ufs3? |
