08-05-2013, 05:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Please Reinstall HWK Support Suite In 2.3.0.0 Please Sir Help Me Anyone |
The Following 10 Users Say Thank You to Yashbanswara For This Useful Post: |
08-05-2013, 06:23 | #2 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1186632 Status: Offline Thanks Meter: 11 | 1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup. 2. Install UFSx Support Suite Setup 3. Connect your UFSx+HWK before running the UFSx Control Panel 4. Run UFSx Control Panel 5. Select the "Hardware" Tab 6. If you only have one UFSx connected it will be selected, if more than one, select the check box next to the required UFSx. You can click "Scan Boxes" to refresh the list if you have connected further boxes since opening the Control Panel 7. Click "Check Box" 8. Click "Update Box" 9. Click "Check Box" 10. Select the "Software" Tab 11. Amend "Application Install Path" and/or Nokia Install Path, if required. 12. Click "Check Server" 13. Click "Install" 14. If you have more than 1 UFSx+HWK run steps 5-13 for each UFSx+HWK (NOTE: You must install something at step 13) You need to uninstall old HWK Setup Suite and HWK Support Suite and use the new UFSx Support Suite. |
The Following 11 Users Say Thank You to deepak gupta For This Useful Post: |
08-05-2013, 23:01 | #4 (permalink) |
No Life Poster Join Date: Oct 2006 Location: USA
Member: 362515 Status: Offline Sonork: 100.1590585 Thanks Meter: 160 | Bro; install this latest suite https://hotfile.com/dl/237828814/80f...00.00.exe.html {it's 02.03.00.01. not 02.03.00.00.} it will help you. { pls search well before u post} |
The Following 7 Users Say Thank You to @matrix@ For This Useful Post: |
08-06-2013, 15:30 | #8 (permalink) |
Insane Poster Join Date: Sep 2009 Location: Gaighat Nepal
Member: 1114945 Status: Offline Sonork: [email protected] Thanks Meter: 14 | antivirus fuli off okkkkkkkkkkkkkkkkkkkkkkk 1000% tested |
The Following 3 Users Say Thank You to ashokshah For This Useful Post: |
08-07-2013, 06:03 | #9 (permalink) |
No Life Poster Join Date: Oct 2007 Location: IN MOBILES
Member: 613242 Status: Offline Sonork: 100.1626311 Thanks Meter: 645 | hmm just reinstall old hwk support suite this ver >> HWK_Support_Suite_Setup_v02.02.000 1000% solve b / r jakkar |
The Following 3 Users Say Thank You to jakkarzoya_2511 For This Useful Post: |
08-09-2013, 09:49 | #11 (permalink) |
Freak Poster Join Date: Jul 2013 Location: PKD
Member: 1987269 Status: Offline Thanks Meter: 190 | Uninstall your old version download latest version disable antivirus update box install this software your problem solve hwk_support_suite_setup_v02.03.000 - Download - 4shared - boy 9440 |
The Following 10 Users Say Thank You to Major Boy For This Useful Post: |
08-12-2013, 10:52 | #15 (permalink) |
Member: 1987269 Status: Offline Thanks Meter: 190 | |
The Following 2 Users Say Thank You to Major Boy For This Useful Post: |
