04-05-2005, 13:26 | #1 (permalink) |
Insane Poster Join Date: Oct 2004 Age: 48
Member: 89061 Status: Offline Thanks Meter: 6 | going insane Heres the problems. I have connect it all up and plug it the phone (1st one) N-gage and it powers up on its own. Then I select the files I want (PPM and MCU) I then press the start button and all that happens is the phone turns itself off and then want come one I leave it for ages and still nothing happens. I have clicked the 'Check' tab and only sometimes it will detect the phone. I have checked the cables and all seems to be ok and every now and then '1st boot error: bad resp UFSx. Rebooting mobile' but nothing else happens apart from the tab at the bottom of the screens says 'Scaning Operating Mode' This is also the same on a 6600. I have installed this on three PC's now. 1st XP details as above still not got it to work 2nd, Windows ME I install as stated in the manual (this shows as UFS in device manager) I open up DCTx and when I click connect it turns off the PC (nice) 3rd on Windows 98 installed and when I open up DCT I get this message “Platform: Win32 on Windows 95 4.10 (Build 67766446 A ) Versions: Ufs2xx.dll 2.1.4, Ufs2xx.sys not fond “ where should this be located I have looked in Phoenix/Usb and its there and also in C/Windows/System. And when I connect and press flash/start, the PW LED flashes and then the RX flashes rapidly and then I get this error " Detected: V 3.30 28-08-2003 NEM-4 (c)NMP 1st Boot Err: Bad Resp UPP, FF FF FF 72 Process Failed, Repowering Mobile" At one point it started to send the flash file but then failed. It seemed it cant reboot the mobile when I am watching this the screen on the mobile try’s to turn on but all it does is show fine black lines across it. I know this mobile is working because I can turn in on with the battery in. So hopefully this is a software issue/driver. Please can someone give the correct driver and how to install it for XP I have installed everything on the CD and none seem to work. And I still havent heared about my registration if anyone from the team is here please can you help I am desperate to get this to work |
04-06-2005, 18:51 | #3 (permalink) |
Member: 89061 Status: Offline Thanks Meter: 6 | thank you for tha I have tried but I still cant get it to work I have noticed that on my other PC when I pres flash the RX LED blinks and the PW led also as if its trying to boot the mobile but this doesnt happen on XP. The mobile does turn on with a battery in but I cant turn in on when it connect to the UFS box Any more ideas please I am desperate to flash my phones |
04-06-2005, 19:10 | #4 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Midlands, UK
Member: 57937 Status: Offline Thanks Meter: 34 | Have you got any normal DCT4 phones to have a go with?! (non WD2) Also this might seem a strange question but how long is the cable on the cables for the 6600 and n-gage, as these handset are power hungry and the longer the cable the lower the performance and the UFS is only USB powered, (not mains powered like a griffin) As I had a problem with a 6600, which was working fine in a griffin as it has a 9v supply, but did nothing on a UFS3, I got a shorter cable and it was then working fine. As my supplier was supplying UFS with sortened cables. Normal DCT4 (non WD2) require less juice for flashing etc. Another reason for your problems might be your USB port not producing enough power for the UFS, are you using a non powered hub |
04-07-2005, 14:43 | #5 (permalink) | |
Member: 89061 Status: Offline Thanks Meter: 6 | Quote:
Not to sure what USB I have its just a normal one built in to the PC, any ideas how I give it more power please! | |
04-07-2005, 15:41 | #6 (permalink) |
Member: 89061 Status: Offline Thanks Meter: 6 | @ 07heaven YOU ARE THE MAN (OR WOMAN) Just got a short cable plugged in the 6600 and flashed away, just cant do the Local mode in UI settings keep getting fatal errors. never mind thank you so much |
04-07-2005, 17:04 | #9 (permalink) | |
Crazy Poster Join Date: Nov 2004 Location: NOTTINGHAMSHIRE Age: 49
Member: 92431 Status: Offline Thanks Meter: 0 | Quote:
Sorry 07 (jim) cudnt resist.......lol | |
Please, Please, Please Help Me With Codes - I Am Going Insane! | janeyjewel | CAR Electronics | 1 | 07-23-2007 00:58 |
Going insane please help | dazzlet | GOT Motorola | 0 | 03-20-2007 19:18 |
T630, insane in the brain | juves | Sony Ericsson | 0 | 03-30-2005 10:03 |
