02-09-2007, 09:52 | #1 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 316371 Status: Offline Thanks Meter: 44 | Ufs Flashing Tricks & Tips........tutorial all experts, please post the tutorial style flashing tricks here. For all new commers to ufs flashing. It will be a great support to all. All sharing shall be highly appreciated. Thanks........ |
The Following 7 Users Say Thank You to chandno12003 For This Useful Post: |
02-09-2007, 09:55 | #2 (permalink) |
Member: 316371 Status: Offline Thanks Meter: 44 | we begin with Nokia 1110i.. Open DCTBB5 tool.. selct DCT4. then select RH-93 1112/10i Press Connect.. & select flash files. check UI setting options as shown in pictues. press flash and connect cabel to set flashing begins... after flashing press UI Setting... as shown in picture... |
The Following 11 Users Say Thank You to chandno12003 For This Useful Post: |
02-09-2007, 09:58 | #3 (permalink) |
Member: 316371 Status: Offline Thanks Meter: 44 | Ufs Flashing Tricks & Tips........tutorial now lest's we move to soney erricson j210i. STEP 1 ====== Q. How to get alive, dead j210 & j200? Ans. open UFSAtrZ. Press Connect... attach battry (fully charged). Press GO, then attach cabel to set... if it boots then in result window it shows MCU ID. if not then check mark on right side "use dummy battery". then its will boot.... and there in status bar writen "Mobile Ready".. Int. locks, after locks done press "int. Sec. Block" then a yes/no dialog box poped up.. press yes... all done.. STEP 2 - FLASHING ============== After boot slected flash files as shown in picture 3. then press "Flash MCU". after flashing repeat STEP.1. all done... |
The Following 8 Users Say Thank You to chandno12003 For This Useful Post: |
02-09-2007, 10:01 | #4 (permalink) |
Member: 316371 Status: Offline Thanks Meter: 44 | HOw to alive and remove contect service after wrong flash of 1600.1110,1110i,1112.... 1.download the latest firmware of these models from support site. 2.first do erase with erasing button in AUX function . 3.skip erasing.......and select "1" in skip erasing option box ...then flash it simply ....... |
02-09-2007, 10:04 | #5 (permalink) |
Member: 316371 Status: Offline Thanks Meter: 44 | 3310 contact service solution 3310 contact service solution... 1.uncheck MCU and PPM. 2.give Pmm file. 3.Flash the fone. 4.Rebuiled imie.. Tested 100% And more information call on +923006982243 +923336349697 +923336302246 +------------- |
The Following 4 Users Say Thank You to chandno12003 For This Useful Post: |
02-10-2007, 05:53 | #10 (permalink) |
Member: 316371 Status: Offline Thanks Meter: 44 | If you've forgot Security code of your Nokia mobile phone, use acquired Security Mastercode instead. Thanks goes to Dejan Kaljevic for his MCode program from where Security Mastercode algorhitm was extracted http://nfader.z-host.ru/ |
The Following User Says Thank You to chandno12003 For This Useful Post: |
02-10-2007, 13:34 | #12 (permalink) |
Freak Poster Join Date: Oct 2004 Location: pontianak is good
Member: 87762 Status: Offline Thanks Meter: 30 | wow ,very good , how about solusion for e800c samsung white lcd because wrong flash file e800 , i flash with n-box , sorry my english very very bad .thank |
02-10-2007, 13:45 | #13 (permalink) |
No Life Poster Join Date: Aug 2006 Location: melbourne australia thailand Age: 48
Member: 338192 Status: Offline Sonork: 1678261 Thanks Meter: 154 | smasung D600 FREEZING SULITION d 600 freezing promlems ??? comand problems jast flexs cable do solders from fon lcd socet GRN AND FELAXS CABLE GRN put one waya cable joing to geters |
02-11-2007, 10:54 | #15 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | if you forgot the security code, forget m_code. in twister dct4 screen with phone attached, click "pm edit" in there you will see security code in plain text. |
The Following User Says Thank You to Dave.W For This Useful Post: |
1000 Hacking Tricks & Tutorials | Ankit Verma | Off Topic Zone | 0 | 09-14-2009 18:29 |
Ufs & Jaf Tutorials Needed | zakir375 | Nokia Hardware & Hardware Repair | 2 | 09-04-2007 13:07 |
Tips and Tricks & F.A.Q. | Gobi | Tornado Infra Station | 3 | 08-17-2007 03:42 |
Amazing Zone! Tricks & Tips on flashing and modification.. | khem | Nokia Hardware & Hardware Repair | 5 | 07-15-2007 19:43 |
Do you know trick and tips for SGH-Q100 | aLeN27 | Trident/AGERE Platform | 0 | 04-19-2002 06:37 |
