Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
05-23-2018, 05:51 | #1 (permalink) |
Freak Poster Join Date: Oct 2015 Location: Bharat
Member: 2479945 Status: Offline Thanks Meter: 32 | lyf ls-5009 flashing error alidating Application Configuration Load APP Configuration COM:-1 PBLDOWNLOADPROTOCOL:0 PROGRAMMER:True PROGRAMMER:F:\andura\andrroid\LYF\Lyf_Wind_6_LS_50 09_V209_160115\Firmware\prog_emmc_firehose_8909_dd r.mbn RESETSAHARASTATEEMACHINE:False SEARCHPATH:F:\andura\andrroid\LYF\Lyf_Wind_6_LS_50 09_V209_160115\Firmware RAWPROGRAM: rawprogram_unsparse.xml PATCH: patch0.xml ACKRAWDATAEVERYNUMPACKETS:False ACKRAWDATAEVERYNUMPACKETS:100 MAXPAYLOADSIZETOTARGETINBYTES:False MAXPAYLOADSIZETOTARGETINBYTES:49152 DEVICETYPE:eMMC PLATFORM:8x26 VALIDATIONMODE:0 RESETAFTERDOWNLOAD:False MAXDIGESTTABLESIZE:8192 SWITCHTOFIREHOSETIMEOUT:30 RESETTIMEOUT:200 RESETDELAYTIME:2 FLATBUILDPATH:C:\ FLATBUILDFORCEOVERRIDE:True QCNPATH:C:\Temp\00000000.qcn QCNAUTOBACKUPRESTORE:False SPCCODE:000000 ENABLEMULTISIM:False AUTOPRESERVEPARTITIONS:False PARTITIONPRESERVEMODE:0 PRESERVEDPARTITIONS:0 PRESERVEDPARTITIONS: ERASEALL:False Load ARG Configuration Validating Download Configuration Search path not exist, ignored: F:\andura\andrroid\LYF\Lyf_Wind_6_LS_5009_V209_160 115\Firmware Invalid programmer path, ignored: F:\andura\andrroid\LYF\Lyf_Wind_6_LS_5009_V209_160 115\Firmware\prog_emmc_firehose_8909_ddr.mbn Process Index:0 Programmer Path:F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\prog_emmc_firehose_8909_ddr.mbn Image Search Path: F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm Image Search Path: F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm RAWPROGRAM file path: F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\rawprogram2.xml PATCH file path:F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\patch2.xml Start Download Program Path:F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\prog_emmc_firehose_8909_ddr.mbn ***** Working Folder:C:\Users\a\AppData\Roaming\Qualcomm\QFIL\CO MPORT_13 Binary build date: Oct 31 2016 @ 22:51:05 QSAHARASERVER CALLED LIKE THIS: 'C:\Program Files\Qualcomm\QPST\bin\QSaharaServer.ex'Current working dir: C:\Users\a\AppData\Roaming\Qualcomm\QFIL\COMPORT_1 3 Sahara mappings: 2: amss.mbn 6: apps.mbn 8: dsp1.mbn 10: dbl.mbn 11: osbl.mbn 12: dsp2.mbn 16: efs1.mbn 17: efs2.mbn 20: efs3.mbn 21: sbl1.mbn 22: sbl2.mbn 23: rpm.mbn 25: tz.mbn 28: dsp3.mbn 29: acdb.mbn 30: wdt.mbn 31: mba.mbn 13: F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\prog_emmc_firehose_8909_ddr.mbn 10:16:58: Requested ID 13, file: "F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\prog_emmc_firehose_8909_ddr.mbn" 10:16:58: 272128 bytes transferred in 0.172000 seconds (1.5088MBps) 10:16:58: File transferred successfully NOTE: Target requested image 13 which is DeviceProgrammer. Forcing QUIT. This is by design, ** All is well ** SUCCESS!! 10:16:58: Sahara protocol completed Sending Programmer Finished Switch To FireHose Wait for 3 seconds... Max Payload Size to Target:49152 Bytes Device Type:eMMC Platform:8x26 Disable Ack Raw Data Every N Packets Skip Write:False Always Validate:False Use Verbose:False ***** Working Folder:C:\Users\a\AppData\Roaming\Qualcomm\QFIL\CO MPORT_13 Base Version: 16.10.28.15.28 Binary build date: Oct 31 2016 @ 22:51:02 Incremental Build version: 16.10.31.22.51.02 10:17:04: INFO: FH_LOADER WAS CALLED EXACTLY LIKE THIS ************************************************ C:\Program Files\Qualcomm\QPST\bin\fh_loader.exe --port=\\.\COM13 --sendxml=rawprogram2.xml --search_path=F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm --noprompt --showpercentagecomplete --zlpawarehost=1 --memoryname=emmc ************************************************ 10:17:04: INFO: Current working dir (cwd): C:\Users\a\AppData\Roaming\Qualcomm\QFIL\COMPORT_1 3\ 10:17:04: INFO: Showing network mappings to allow debugging 10:17:05: INFO: 10:17:05: INFO: Trying to store 'rawprogram2.xml' in string table 10:17:05: INFO: Looking for file 'rawprogram2.xml' 10:17:05: INFO: User wants to talk to port '\\.\COM13' 10:17:05: INFO: Took 0.01600000 seconds to open port 10:17:05: INFO: Sorting TAGS to ensure order is <configure>,<erase>, others, <patch>,<power> 10:17:05: INFO: If you don't want this, use --dontsorttags 10:17:05: INFO: Looking for file 'platform_ddr.bin' 10:17:05: INFO: Looking for file 'gpt_main2.bin' 10:17:05: INFO: Looking for file 'gpt_backup2.bin' 10:17:05: INFO: Total to be tansferd with <program> or <read> is 33.91 KB 10:17:05: INFO: Sending <configure> 10:17:05: INFO: TARGET SAID: 'logbuf@0x08057C78 fh@0x08054AE0' 10:17:05: INFO: fh.attrs.MaxPayloadSizeToTargetInBytes = 1048576 10:17:05: INFO: fh.attrs.MaxPayloadSizeToTargetInBytesSupported = 1048576 10:17:05: INFO: In handleProgram('platform_ddr.bin') 10:17:05: INFO: Looking for file 'platform_ddr.bin' 10:17:05: INFO: ================================================== ===== 10:17:05: INFO: {<program> FILE: 'F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\platform_ddr.bin'} 10:17:05: INFO: {<program> (420.00 B) 1 sectors needed at location 34 on LUN 2} 10:17:05: INFO: ================================================== ===== 10:17:05: INFO: TARGET SAID: 'logbuf@0x08057C78 fh@0x08054AE0' 10:17:05: INFO: TARGET SAID: 'start 34, num 1' 10:17:05: INFO: FILE ACCESS SLOW!! 512.00 B in 0.015 seconds ( 33.33 KBps) --- Overall to target 0.010 seconds (50.00 KBps) 10:17:05: INFO: {percent files transferred 1.21%} 10:17:05: INFO: TARGET SAID: 'Finished sector address 35' 10:17:05: INFO: 10:17:05: INFO: ================================================== ===== 10:17:05: INFO: ==================== {SUCCESS} ======================== 10:17:05: INFO: ================================================== ===== 10:17:05: INFO: {percent files transferred 1.21%} 10:17:05: INFO: In handleProgram('gpt_main2.bin') 10:17:05: INFO: Looking for file 'gpt_main2.bin' 10:17:05: INFO: ================================================== ===== 10:17:05: INFO: {<program> FILE: 'F:\andura\andrroid\LYF\WIND 6 LS-5009-S11A_By Gsm_F!rmwares_Tm\gpt_main2.bin'} 10:17:05: INFO: {<program> (17.00 KB) 34 sectors needed at location 0 on LUN 2} 10:17:05: INFO: ================================================== ===== 10:17:05: INFO: TARGET SAID: 'start 0, num 34' 10:17:05: INFO: FILE ACCESS SLOW!! 17.00 KB in 0.015 seconds ( 1.11 MBps) --- Overall to target 0.016 seconds (1.04 MBps) 10:17:05: INFO: {percent files transferred 51.34%} 10:17:05: INFO: TARGET SAID: 'Read back verify failed at sector 1229944438,num sectors 0' 10:17:05: INFO: TARGET SAID: 'Finished sector address 0' _____ | ___| | |__ _ __ _ __ ___ _ __ | __| '__| '__/ _ \| '__| | |__| | | | | (_) | | \____/_| |_| \___/|_| 10:17:05: {ERROR: Please see log} Writing log to 'C:\Users\a\AppData\Roaming\Qualcomm\QFIL\COMPORT_ 13\port_trace.txt', might take a minute Log is 'C:\Users\a\AppData\Roaming\Qualcomm\QFIL\COMPORT_ 13\port_trace.txt' Download Fail:FireHose Fail:FHLoader Fail:Process fail Finish Download |
