Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various
Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it......
Old 03-14-2014, 12:09   #1 (permalink)
Member: 2141811
Thanks Meter: 38
[MTK 65xx DEVICES] IMEI REPAIR TOOLS
NOTES:
  • IMEI Missmatched Or Broken Is Common Problem On Many Chinese MTK 65xx Android Devices
  • I Will Present You 3 PC Apps Which Can Help You To Recover IMEI Number(s) In Order That Your Device Work Normal Again
  • Please Enable On Your Device Settings → Security → Unknown Sources & Settings → Development → USB Debugging
  • Purpose Of This PC Apps Is Only Recovery Of IMEI Number - Please Dont Use It For Any Illegal Activities
【APP】 MAUI META 3G
【Software Information
Software Name:MAUI META 3G
Source Link:No Link - Developed By MEDIATEK INC
【Software】
All MTK Devices Baseband Run On NVRAM - Path In Androids Phones "/dev/nvram"
You Can Use 2 Ways To Reflash NVRAM.
- One By Flashing BPLG Baseband (Modem)
"MAUI_1XAMD_W1X_XX_SP_V1X" (Where X Is Some Number Depending On Device Specs)(Basic Functions Like Imei ,Etc Works With Most Alternative BPLG Files)
- Once NVRAM Is Corrupted You Must Use Flash Tool Solution With Correcting Scatter From ''__NODL_NVRAM'' To ''NVRAM'' And Select Correct Working Phone NVRAM File For Same Baseband.
MAUI META 3G Instructions:
  • Power On Phone
  • Connect Phone To Pc
  • Asking Drivers Give Him
  • Than Turn Off Phone
  • Open Maui Meta Tool
  • In Options Trick Second One ( Connect Smart Phone Into A Meta Mode)
  • Press Reconnect
  • Than Inset Cable
  • Asking Cdc Drivers Install ,Browse For Them In CDC Driver Archive
  • After 1 Min Popup Imei Tool Tab
  • Than Press ( Change Nvram Database File) And Chose It From NVM Archive
  • Write IMEI (One Or Both Depending On Device)
  • Press Download To Flash
【Software Downloads】
DOWNLOAD MAUI META 3G SOFTWARE
DOWNLOAD CDC DRIVERS
DOWNLOAD ALL MTK (BPLGU) MODEM (BASEBAND(NVRAM)) FILES
【APP】 IMEI & SN WRITER
Software Name:IMEI & SN WRITER
Source Link:No Link - Developed By CKT Technology
【Software】
- One By Flashing BPLG Baseband (Modem) "
IMEI & SN WRITER Instructions:
- Check Video Instructions Bellow -
【Software screenshot】
DOWNLOAD IMEI & SN WRITER SOFTWARE
【APP】 SN WRITE STATION
Software Name:SN WRITE STATION
【Software】
SN WRITE STATION Instructions:
1.Open SN Station IMEI Tool
Switch AT Mode and adjust PowerON Delay Time(s):5
2.After adjust the Delay Time(s) and change switch to Meta Mode
Select Write IMEI and Smart Phone
Put the cable to the Mobile and select the COM PORT(Look In Windows Device Manager For Device Modem COM Port)
Select the Dual IMEI
3.Then Select the Modem Database and select the BPLGU file
Select which database file need ( ex :- Mtk6575 6516 etc ...)
4.Select the Modem Database and select the APDB file
5.Then Click on START and enter IMEI (IMEI - s) Numbers You Want To Write
6.IMEI Is Repaired - Reboot Mobile Device
DOWNLOAD SN WRITE STATION SOFTWARE
DOWNLOAD ALL MTK (BPLGU) MODEM (BASEBAND(NVRAM)) FILES AND APDB FILES
AND FOR THE END HERE YOU HAVE AN ANDROID APP MADED BY UNNAMED MTK EMPLOYER FOR REPAIRING IMEI DIRECTLY FROM ROOTED DEVICE.
MTK65xx-imei_EN.apk
The Following 5 Users Say Thank You to bishnuprasad884 For This Useful Post:
Old 03-14-2014, 13:29   #2 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
Nice
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post:
Old 08-21-2015, 13:36   #3 (permalink)
Member: 683295
Thanks Meter: 3
Hy,
thanks for tut,what system operating I need ... xp , windows 7 ?
The Following User Says Thank You to mariuspytu2 For This Useful Post:
Old 08-21-2015, 15:12   #4 (permalink)
Member: 683295
Thanks Meter: 3
I need MT6575ini file
Old 06-16-2016, 01:00   #5 (permalink)
Member: 2172100
nice one...i have lenovo s660 with imei null/null after flashing with new row rom..i hope this thread can solve my problem...thanks...
Old 11-22-2016, 16:10   #6 (permalink)
Member: 2246493
Sonork: 100.1658338
Thanks Meter: 6
plz help dis q380 imi invelid
The Following User Says Thank You to sanu bhai For This Useful Post:
Old 12-07-2017, 16:03   #7 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
good copy paste
[MTK 65xx DEVICES] IMEI REPAIR TOOLS - App - Xiaomi MIUI Official Forum
Page generated in 0.24145 seconds with 8 queries
