Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
09-28-2006, 18:44 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Dublin
Member: 16771 Status: Offline Thanks Meter: 153 | Hot!!! Hot!!! Unlocking A Voip Phone - Free Solution!!! UNLOCKING A VIOP PHONE We have figured out a way to unlock his Linksys "Vonage" PAP2 unit to work with other vendors... Like free services from fringe vendors. These units are basically ATA's. That is, it has two RJ11s you hook regular phones to, and a RJ45 that goes to your network. It takes your "regular phones" and turns it into a VoIP phone. Model: Linksys "Vonage" PAP2 (Model No: PAP2). Files needed: PAP2SP2K.bin and SP2KPAP2.bin Download files at these links below http://www.broadbandreports.com/r0/download/897422~b9615bb0674b11bc6e23e4876bd7e680/PAP2SP2K.zip http://www.broadbandreports.com/r0/download/897423~37dc1fdc39f88c2ecbc21750ea7503f6/SP2KPAP2.zip Follow these steps and your Linksys PAP2 will be unlocked. Provider settings do not get erased. Several assumptions: 1. you can get to the WEB interface and set the USER password. 2. Ideally, the device has never downloaded updates, or talked to the provider. 3. You have a TFTP server setup on your network For this example, Assumptions: PAP2 is at IP: 192.168.1.5 TFTP server is : 192.168.1.110 OK, let’s go for it: 1. Put the following two files in the TFTP root folder. [File one: PAP2SP2K.bin and SP2KPAP2.bin Those unfamiliar with Trivial FTP, it's different than regular FTP and you need a special server, such as this free one here: http://www.solarwinds.net/Tools/Free_tools/TFTP_Server/ 2. Disconnect from the Internet (avoids downloading cfg files) 3. Boot your PAP2 in your network. 4. Browse to the web page of the PAP2. 5. In SYSTEM, set a User password of 1234 6. Click the SAVE SETTINGS button. 7. Refresh the link (you login with user and 1234) 8. Modify the link to show (in your web browser!): http://192.168.1.5/upgrade?tftp://19...0/PAP2SP2K.bin 9. Examine the status leds.. Power should turn RED when it is done. Give it a minute or two, dont interrupt it. 10. Once red, point browser at your PAP2. (our IP in this example is 192.168.1.5) 11. Click the "admin login" link near the top-right. 12. Click the PROVISIONING tab and set PROVISION ENABLE=NO. 13. Click SAVE SETTINGS. 14. Now, modify the link to show: http://192.168.1.5/upgrade?tftp://19...0/SP2KPAP2.bin 15. Done. Your Linksys PAP2 will eventually reboot (2 blue LEDs) (BE PATIENT) and you can click the "admin login" near the top-right. No PW needed. This test uses specific firmwares. These are not for any other use, so if you are looking for upgrade firmware for your PAP2, DO NOT assume that this will be them.. These are for unlocking your PAP2 unit. also attached as a PDF |
09-29-2006, 13:13 | #4 (permalink) |
Member: 16771 Status: Offline Thanks Meter: 153 | NEW DOWNLOAD LINKS - download below while you can http://www.angelfire.com/droid/pap2/PAP2SP2K.zip http://www.angelfire.com/droid/pap2/SP2KPAP2.zip Br Alan Donohoe Gsm Solutions Ltd www.GsmSolutionsLtd.com |
thanks to setool team T715 cid53 unlock done few second free | kadricom | SETool2 | 6 | 02-16-2011 10:38 |
Skype USB Phone VOIP Phone | IPMART | ipmart WebShop | 0 | 02-27-2010 17:30 |
hello microbox team this 3sagem phone phone free unlock or need cridets | ayhen42 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2 | 11-16-2008 05:28 |
MITSHUBISHI PHONES FREE UNLOCKING | rrakip | Mitsubishi | 0 | 05-18-2001 18:49 |
Unlock your own phone for free! | MrProdent | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-19-1999 16:00 |
