Please i need BOSCH 908/909 pin outs.. Hi guys Is there any one who got this pin outs.... I have Bosch unlocker cracked so it gives ALL locks /not the Demo ver./ THANKS BYE |
Hello, first pin from right is GRD and secound pin from left is C-BUS. Best regads, mobileinfo |
Hi Can you send this Software to me ? Thanks Jan |
i cant find exactly procedure for boot oc.c1, i tried to use procedure boot 6.36/6.71/6.81 but dont work for me info appear on screen please ensure that you have used appropriate smart testpoint and its connected properly. using smart tp AT163 smart tp 2. phone now shows on screen PH Sig Err: 35:02: |
Bottom Pin Name Direction Description 1GND Ground, for all Bosch 9xx 2 DCD -?- Data Carrier Detect 3 DTR -?- Data Terminal Ready 4 RTS -?- Ready To Send 5 CTS -?- Clear To Send 6 DSR -?- Data Set Ready 7 IGN -?- Outside Device Present, if so put not more then 2,7 Volt in 8 GND Ground 9 SPK -?- Speaker, needs to be amplified 10 GND ANA -?- Ground analog 11 MIC -?- Microphone Elektret 12 PHP -?- Phone Present, puts out a LOW, it"s not ground 13 HEADSET -?- HeadSet Present, put a LOW in Sounds switched to HeadSet 14 TXD -?- Transmit Data 15 -?- that we dont know, but used by Bosch-Applications 16 BATT -?- Battery +, max. 10mAmps 17 -?- that we dont know, but used by Bosch-Applications 18 RXD -?- Receive Data 19 CBUS -?- CBUS for programing the phone - applicable to all Bosch 9xx 20 CHARGE -?- Charge + not more than 7 Volts Pins other than GND, CBUS may be different in other than 909Dual models! here is the full pinout of bosch 909 |
