Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
03-30-2006, 00:02 | #1 (permalink) |
Registered User Join Date: Dec 2002 Location: The Netherlands Age: 41
Member: 19168 Status: Offline Thanks Meter: 55 | Which program for multiprog 2001 xl? i got a multiprog 2001 xl, but I don't know which software should I use to be able to program the pic 12c509a with it. I already got twoprog314, but it doesn't support 12cxx pics. some help is gladly welcome, thanx |
03-31-2006, 13:36 | #4 (permalink) |
No Life Poster Join Date: Apr 2004 Location: ?
Member: 60699 Status: Offline Thanks Meter: 189 | hi again , i'm not good enough in english maybe this will help you configuration of multiprog 2001 xl 1-press F1 or F2 button until you see: 3 picprog (jdm) 2- press SELECT button and now you can see: a picture of a circuit on the multiprog lcd and before all i hope you didn't forget to put your ic in the right socket Installation & Configuration of ic prog Unzip icprog_.zip to a directory of your choice. Run icprog.exe. The first time you run icprog.exe, you will be prompted with a ”Hardware Setup” screen. Set it up as shown below. Note, the COM Port will be automatically selected for you, but you can always change it. Windows 2000 users add the icprog.sys file to you system directory to run in win 2k. Go to Settings / Options / Misc and check ”Enable NT/2000 Driver”. Windows XP users Open a browser and select the file ic-prog.exe Press right button on your mouse Go to Propertties Go to Compatibility menu Set compatibilty mode as Windows 2000 or Windows 98 / Win ME Press Apply icon Press Accept icon You need to copy icprog.sys into the SAME directory as icprog.exe. Then you can enter in the ic-prog software, go to Settings, Options and choose the Misc. page. There you can enable the NT/2000 Driver it will then be installed. Programming the PIC Select your device (as on picture below) for eg 12C508 Select Oscillator value / eg .12C508/a use internal clock Open the file you wish to program For Fuse Settings see the picture below: Click the Program icon to start the process. Before programming a 508 chip This fix may be required for some programmers. Read the chip, scroll down to the bottom right address 01f8 Read the 01FFh write it down, make sure the code you are programming in has the same address. EG 0c5c If it does not, load the code you are going to program, double click on the address a popup editing box will come up. In the Hexadecimal box enter the same 4 characters as on the blank chip. Now you can program as normal. and finaly don't forget to post result best regards maxim4747 Last edited by sifou474; 04-01-2006 at 12:28. |
Which maps for TomTom one XL? | atukhi | GPS devices , Navigators & Maps | 0 | 02-05-2010 22:16 |
I Whont Know How make Multiprogramer 2001 XL | sonic_master | Sim Cloning and Scaning | 0 | 04-14-2005 06:43 |
which program for updating Software? | chrishlp | x1x to x45/x50 | 1 | 05-05-2003 07:05 |
Does anyone know the best program for a 6150 4.12,all the programs which i know only | dira33 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-16-2001 17:29 |
