Sendo 570 and Smartclip After try to unlock with smartclip, phone won't start on its own.. but when conect to smartclip, it starts... What to do?? Regards |
Check the battery contacts on the phone...Quite common on the 550 that the data lead "bends" one of the contacts....Worth a try, 'cos there is no other real reason for failure. |
m570 unlocked with smartclip you should have read the smartclip manual carefully has it specifically states if you unlock sendo phones with smartclip you either use battery fully charged or just with the smartclip power from connector if you join both it will unlock phone but will screw the battery thats why it is not powering on just with the battery but if u plug it into the m550/570 ps2 connector kit it will poer on because the kit itself send power through the cable . if that is not the case then forget all i've just said :p |
Daniel, come to see me tomorrow, i will show you. -- Jeremy |
Problem solved...Thanks all You were write...it was tehnical problem of user ( no atention LOL )... |
Could you help me unlocking a Sendo M570? Is it possible to unlock it bay Imei? Thanks!! |
in some country posible to buy codes from operator , but never here-calculator for sendo-. |
Hit mate, how long it take to finish sendo 570 unlocking? Quote:
Problem solved unlocked three times with bat on clip and 3/4 bat on phone. Still not good. Unlocked with power supply on clip and no bat on phone, unlocked in 2 sec. But problem is phone doesn't turn on. Soln: put back cover so that battery will have full contact to it's power pins hehehe. And Voila phone is unlocked and working fine.... so far! don't know what will happen next. Very unpredictable. WBR, blutac |
this phone sometimes donīt power on with direct power....only with original baterie |
could you tell me how to unlock sendo m570 with sendo test mode on start up before the logo appears , do u know what is this test mode I did 100's sendo but not that models roland :confused: |
the best solution for sendo.... Delok cheap solution, fast connection with the phone, and in two seconds can be unlock it All models, and best support regards |
