06-08-2005, 06:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 59732 Status: Offline Thanks Meter: 47 | 3230 ring problem |
06-08-2005, 07:34 | #2 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ro Age: 43
Member: 126197 Status: Offline Thanks Meter: 26 | To identify if is hardware or software problem you can do: - change speaker (if you have another phone or a known good speaker) , if sound level is normal >> speaker damaged , ifproblem persists >> check pcb (resistance between speaker pads are more than hundred Kohms and between speaker pads and ground is very big, check for approximate value in service manual or on another pcb) , also clean speaker pads .If pcb is ok >> then try fullflash the phone with mcu,ppm,cnt,pmm (backup your pmm before flashing) and if problem persist than look like UEM problem (UEM amplify the ringtone for speaker). Good Luck |
nokia 1112 ring problem ear pice problem plz hlp | WHED | Nokia Hardware & Hardware Repair | 1 | 11-07-2008 13:58 |
n620 no ring problem | Chawkiz_gsm | VLSI, Conexant, Skyworks and Old Models | 10 | 06-01-2005 12:05 |
T191 ringing problem... | kranegsm | Motorola ODM | 7 | 09-27-2004 18:31 |
A800 ringing problem | GSM Deals | Samsung Hardware Repair | 0 | 07-30-2003 20:47 |
8210 ring problem | jak2812 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-18-2003 20:46 |
