6100 contact service problem i´ve one 6100 in contact service, i´ve flashed it but still in contact service but if i reboot it in normal mode with twister it turn on and all perfect, but if i insert one battery it goes to contact service someone know how to resolve this problem? many thanks |
Hi This might sound stupid but have you tried with another battery instead of the one it came with ? The only difference i can see is that when you boot it ok with the twisterbox you are not using the battery, everything else is the same.. Twisterfan |
yes, i tried with diffrent batteries, allways the same thing: contact service |
I have this problem on 8310 upp may cause this problem |
I would like to find an aswer too, I have a 6100 stuck in a drawer that does exactly the same thing .. I forgot it was there until I read this post :) |
if you are using a new version try an old flash file and if using an old one try a new flash file. differant versions are required for older phones ian @ fonefix |
try to flash it as 3100 dont forget use good pm or u need rpl from griffen team |
