05-18-2005, 23:31 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Germany , Bavaria Age: 45
Member: 37125 Status: Offline Thanks Meter: 19 | Big Problem: Unexpected Exception:BOX_AUTH_ERROR:20 a good friend of me has Twister Serial 40XXX with this Problem Unexpected Exception:BOX_AUTH_ERROR:20. How can we solve the problem ? Because of this Problem, we would make a Firmware Update from the Twister. But when we select the REQ.FBI file from the Support Area , the Twister work a little bit and the it shows me that Error: Unexpected Exception:BOX_AUTH_ERROR:00000000 And the 40xxx.req File isn't at the Phoenix directory. If testet do make the Update with TwisterSuite 1.31 , 1.30 , 1.28 but it didn't work , at every Version are the same Errors . The Problem comes with the Update from the Twister Suite 1.28 to 1.31. What can we do ? The Reseller can't help me , because we can't make a 4xxxx.req File . Is the Twister damaged ? Thank you |
The Following 3 Users Say Thank You to MisterX GSMFREE For This Useful Post: |
05-19-2005, 07:48 | #2 (permalink) |
No Life Poster Join Date: Dec 1999 Location: Sweden Age: 45
Member: 739 Status: Offline Thanks Meter: 0 | i don't think it's damage and i think that it can be repaird there is something with the firmware of the box and need to be repair try to see if you can get any from the supports attantion! Seems like they have fly away on a vacation Maby Raskal is back try to talk to him thru here. Br Gsmhq |
05-19-2005, 08:53 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Please contact your RESELLER Please contact your RESELLER, to send you the FBI files for your twister but you must send the GENERATED file "XXXXXXX.reg" to your reseller |
The Following User Says Thank You to RNC_EBM For This Useful Post: |
05-19-2005, 08:54 | #4 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: UK
Member: 90865 Status: Offline Thanks Meter: 1 | Quote:
The error you get is because the box firmware is not matching the program versions. Note that Sams is broken in 1.31, so before you install 1.31 save the 1.30.001 version of sams.exe and use that instead or you will have problems flashing various phones including A800 and E710 at least. Hope this advice works and is useful. | |
05-19-2005, 09:05 | #5 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | @all After Twister Suite Update from 1.28 to 1.31 shows ous this Error : Unexpected Exception:BOX_AUTH_ERROR:20. After that: Then we downgrade the TwisterSuite back to 1.28 , but it shows this Error again . Then we Upgrade to TwisterSuite 1.30 and TwisterSuite 1.30.001 but it shows this Error again. Then we Upgrade to TwisterSuite 1.31 but it shows this Error again . After this all: We download the REQ.FBI from Twister Support Area , start DCTx 1.3j and made a FIRMWARE UPDATE with this REQ.FBI File. But this don't work , it shows ous this Error : Unexpected Exception:BOX_AUTH_ERROR:00000000 And there was no File 4XXXX.REQ at the Phoenix directory. So after that error , we delete the TwisterSuite 1.31 again. And install the TwisterSuite 1.30 again. Then we started DCTx again , made FIRMWARE UPDATE with the REQ.FBI File. But it doesn't work , the same Error like on TwisterSuite 1.31 (Unexpected Exception:BOX_AUTH_ERROR:00000000) And no 4xxxx.REQ at the Phoenix Directory. Thats the Problem |
05-19-2005, 09:11 | #6 (permalink) |
Member: 739 Status: Offline Thanks Meter: 0 | as i said the firmware inside the box is damage as i see it i think it is corrupted, i think your reseller need to have a big look on it maby send it to twister to fix it. but i can't say this really becuase i am not 100% good on this with firmware and stuff but it seems like the firmware inside the box is corrupted or something! Br Gsmhq |
05-19-2005, 10:08 | #7 (permalink) |
No Life Poster Join Date: Dec 2002 Location: lebanon-tripoli
Member: 18966 Status: Offline Thanks Meter: 59 | same problem with ufs3 gold after upgrade to dctx1.3h it work for 2 day after that it do same pb with me and i do same procedure but no success now i am waiting answer from ufx office but my problem is from where i bought the box he is not the resseller anymore there is another one. |
05-19-2005, 13:15 | #8 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | @MisterX GSMFREE Try this:- Uninstall TwisterSuite AND USB Driver Make sure all folders have gone, if note delete them e.g. \Program Files\Nokia\Phoenix \Program Files\SarasSoft\Twister Install Suite 1.28 and use the USB driver from this install:- \Program Files\SarasSoft\Twister\USB Driver Run DCTx ignore any messages and try to update the firmware with req.fbi, if a xxxxxx.req is not generated, try to update firmware with an old xxxxxx.fbi and then use req.fbi I think you must get twister working at 1.28 before upgrading, let me know how to get on. Odia. |
05-19-2005, 21:18 | #10 (permalink) | |
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Odia. | |
09-02-2007, 20:55 | #13 (permalink) |
Freak Poster Join Date: Jun 2006 Location: i live in islamabd pakistan Age: 47
Member: 299723 Status: Offline Thanks Meter: 7 | the same problem with me i am sure there is problem with my box firmware but how to fix no one knows my reseller says i cannot do coz they just know selling theyr not serious fixing problems this is mean attitude |
The Following User Says Thank You to mizhar_khan For This Useful Post: |
02-03-2009, 17:19 | #14 (permalink) |
Junior Member Join Date: Jul 2007
Member: 555789 Status: Offline Thanks Meter: 1 | This seems all to be bull--we run 3 boxes and each one went out of order with that box_auth_error.believe this is big set up from producersside (or whoever is responsible for that ****)---they are again trying to suck money from us---like all other flasherbox vampires!!!! |
The Following User Says Thank You to maurice11 For This Useful Post: |
02-05-2009, 16:47 | #15 (permalink) |
Major Poster Join Date: Apr 2008
Member: 756490 Status: Offline Thanks Meter: 1 | After Twister Suite Update from 1.28 to 1.31 shows ous this Error : Unexpected Exception:BOX_AUTH_ERROR:20. After that: Then we downgrade the TwisterSuite back to 1.28 , but it shows this Error again . Then we Upgrade to TwisterSuite 1.30 and TwisterSuite 1.30.001 but it shows this Error again. Then we Upgrade to TwisterSuite 1.31 but it shows this Error again . After this all: We download the REQ.FBI from Twister Support Area , start DCTx 1.3j and made a FIRMWARE UPDATE with this REQ.FBI File. But this don't work , it shows ous this Error : Unexpected Exception:BOX_AUTH_ERROR:00000000 And there was no File 4XXXX.REQ at the Phoenix directory. So after that error , we delete the TwisterSuite 1.31 again. And install the TwisterSuite 1.30 again. Then we started DCTx again , made FIRMWARE UPDATE with the REQ.FBI File. But it doesn't work , the same Error like on TwisterSuite 1.31 (Unexpected Exception:BOX_AUTH_ERROR:00000000) And no 4xxxx.REQ at the Phoenix Directory |
unexpected exception:BOX_AUTH_ERROR:20 | bannu | HWK | 23 | 12-23-2008 20:46 |
