Cant flash with DCTxBB5 1.4d Hello I have a big problem with DCTxBB5 1.4d Cant flash 3200, always Error: Detected: V 5.34 11-02-05 RH-30 3200 (c) Nokia 1st Boot Err: Bad Resp UFSx Process Failed, Repowering Mobile But DCTxBB5 1.4c flash with no problems. Same with another phones (3510) Whats the problem? |
DCTxBB5 - NOT WORKING SOLUTION for "Bad Resp UFSx" try to change you USB CABLE - TESTED by ME, 100% WORKING br RNC_EBM |
I can read phone info, but with flashing always this error Do you think bad USB Cable? But this cable work for all older version and is the original cable from package |
I think you should test your Twister on a other PC . I could be a Windows Problem , because I have no errors with DCTxBB5 1.4d and this phones ( 3200 , 3510 ) . |
I have same problem with 5210. I must flash her by Universal Box. br, fingusio |
Test on other PC... I spent one hour flashing 6230i... then was "smart" to change PC and flashed the phone at first :D |
I will test another USB Cable, but i think the problem is the new USB Driver 1.4d and the USB Cable work very good on another PC, no errors, but on my WorkPC not... |
And maybe try to uninstall twister suite and install it again. (Try to use 1.31) That solved last time my problem with 2600 |
check always show 1st Boot Err: Bad Resp UFSx 1st Boot Err: Bad Resp UFSx Rebooting Mobile your problem solve core-based computers I3, I5, i7. par nahi chalega agar chalana hi hai to bios ki setting karni hoti hai kar ke chala sakte hai aur agar samajh me nahi aaya to call kar sakte hai +919453887942 gaurav singh [email protected] gaurav mobile care azamgarh u.p. Don't forget thanks |
new solution check always show 1st Boot Err: Bad Resp UFSx 1st Boot Err: Bad Resp UFSx Rebooting Mobile your problem solve core-based computers I3, I5, i7. par nahi chalega HWK Major Suite_v02.02.000 HWK_Support_Suite_Setup_v02.02.000 aur agar samajh me nahi aaya to call kar sakte hai +918291149555 gaurav singh [email protected] gaurav mobile care azamgarh u.p. Don't forget thanks |
