Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 04-18-2005, 07:29   #1 (permalink)
Member: 49428
Thanks Meter: 45
Frusterated with Nokia 3220!!!
I am having problems getting twister to work...
This is my first time using twister please tell me what i did wrong...
I have a nokia 3220b:
This is what I did...
1) Installed Twister Suite
2) Connected Twister Box + Detected Drivers
3) Opened DCTx
4) Press Connect Button
5) Checked on "Init Simlock" Under "UI Options"
6) Clicked on "UI Settings"
7) no response
8) Clicked on Info
9) Nothing appeared
10) Clicked on "check"
get this message :
1st Boot Err: Bad Resp UPP, 03 00 00 72
1st Boot Err: Bad Resp DCT3
Rebooting Mobile
Read the trouble shooting... went back and checked wires and did step 5 - 10 again... same thing... this is really frusterating... really how hard is it to unlock the phone?
(before i always u free dct calc but cannot do to this one because I don't know who its locked to to do a provider code)
TH
BTW: The connections are good because I tested with different fone... + when connected the 3220b does say "Local" and cycles thru rebooting like any other fone... just some reason its not being detected by twister... please help as this has been a pressing matter for some time... thanks!!
Old 04-18-2005, 10:05   #2 (permalink)
psych0's Avatar
Member: 4184
It is cable problem I am 99% sure.
Sometimes I have to remove the board from the chassis and keep the phone and the cable in my hands to detect, unlock and flash the phone.
Old 04-18-2005, 15:25   #3 (permalink)
Member: 49428
Thanks Meter: 45
U kidding me rite?
How can it be the cable if the phone shows "Local" and responds to all reset commands sent to it?
-Kab
Old 04-18-2005, 15:47   #4 (permalink)
evan_silbert's Avatar
Member: 21920
Thanks Meter: 10
Make sure you are not using a USB hub.
Make sure there is plenty of USB power.
Make sure the USB cable you are using is a good one.
Connect phone, open Twister, Press "Connect".
Click DCT4 tab.
Click "Check"
When completed, click "Info"
When completed, DOUBLE CLICK "Init Simlocks"
In 3 seconds or less the phone is unlocked.
Old 04-18-2005, 17:13   #5 (permalink)
Charly's Avatar
Member: 2008
Thanks Meter: 4
This is because you have not selected the right Phone 3220 is DCT4 not DCT3 which you have selected
Twister will not auto select between DCT3 and DCT4 you must click the correct DCTX range in the right hand side of your Software.
Regards
Charlie
Old 04-18-2005, 17:40   #6 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,032
Regards
Charlie
Not true, if no DCT4 algo can be found DCTx will revert to DCT3.
This error could be due to damaged UPP.
Odia.
Old 04-18-2005, 18:58   #7 (permalink)
Member: 16927
Sonork: 100.1592866
Thanks Meter: 133
Few days ago i have strange 3220 too. When using "Check" i have also:
Rebooting Mobile
When using "Info" button i can read all info about phone
When using "Flash" button also:
Rebooting Mobile
Whats mean UPP damage??
br.
fingusio
Old 04-18-2005, 23:46   #8 (permalink)
Charly's Avatar
Member: 2008
Thanks Meter: 4
Odia.
Most of my cables or phones must be damaged then
I can never get DCT4 to show info without first selecting DCT4 in menu.
Charlie
Old 04-19-2005, 00:01   #9 (permalink)
Member: 21920
Thanks Meter: 10
I think he is saying if you select DCT4 and it can't find the right algo, it assumes you made a mistake and tries DCT3. You do need to select DCT4 first though.
Old 04-19-2005, 02:57   #10 (permalink)
Member: 49428
Thanks Meter: 45
Exactly what it does...
@Evan... the USB port I am using is direct to mobo...
I tried with a different model phone it works fine... just this 3220b has issues i dunno why...
-Kab
Old 04-19-2005, 03:04   #11 (permalink)
Member: 21920
Thanks Meter: 10
Try another 3220 or 3220b. If you still have problems, you need a new 3220 cable.
Old 04-19-2005, 04:20   #12 (permalink)
Member: 49428
Thanks Meter: 45
Once again...
(Twister Connected via USB. Phone connected to Twister via 3220b cable. Phone automatically says "Local". LCD is not lit except for "Local" is displayed.)
1) Started DCTx v1.3_i
2) Clicked on "Connect"
Get this message :
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 7
UFS_USB V2.6 (c) SarasSoft 2005. S/n: 92331
Licence : True
Features: 00000001
3) Clicked on DCT4 Tab and selected "RH-49 (3220b)"
4) Clicked on "Check"
(during this time i hear the phone click a few times + "Local" fades in and out)
Get this message :
1st Boot Err: Bad Resp UPP, 02 FF FF 72
Rebooting Mobile
5) Clicked on "Info"
a) Status bar says "Scanning Operating Mode" (lower left of the program)
(waits for a good 3 minutes)
b) Status bar now says "Idle". nothing in the display box.
6) Double click on "Init Simlock"
a) a dialog box pops up "Error in IMEI, Initialization aborted"
b) so i click "OK" to close the dialog box
Get this message :
Init Test Mode Failed
IMEI: ---, ASIC:
Now I try something new..
7) Scenario i changed to "UI Options" (instead of "Flash + UI")
a) Interface I changed to M-Bus
b) Speed I changed to Slow
c) In "UI options" i checked "Init Simlock"
d) I hit the "Start" button
After awhile this is the message i get:
Cannot Detect Mobile Brand
IMEI: ---, ASIC:
Am really out of ideas for write now... maybe sarasoft coders could explain what this all means as I dont see it in the trouble shooting section...
-Kab
Old 04-19-2005, 05:34   #13 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
I have these sorts of problems ALL the time.
The cables are often quite dodgy, just jiggle the thing around in the battery socket for a bit and you can usually get it to work.
I just assumed this was a common issue, if you don't jiggle them just right they don't work!
Old 04-19-2005, 08:23   #14 (permalink)
LogoMan's Avatar
Member: 17431
Thanks Meter: 22
Originally Posted by KaBLooMz
Once again...
Get this message :
Licence : True
Features: 00000001
Get this message :
Rebooting Mobile
Get this message :
IMEI: ---, ASIC:
IMEI: ---, ASIC:
-Kab
Hi mate, to check if phone is connected to soft, see phone screen if displays "local mode" if not power on manually and if all ok, tick info, this time software will read phone info, if not phone not connected properly to soft, even it display "local mode", check cable contacts
And removed you S/N
BR,
LogoMan
Old 04-19-2005, 10:11   #15 (permalink)
Member: 49428
Thanks Meter: 45
hi muppet i'll give that a shot... u on a sony ericson forum rite?
(btw if its a bad connection.. how come my fone still says Local? and still cycles reboot fine?)
@Logoman
I did mention that my fone does power up and say "Local" on the actual fone screen... so i dunno i think that alone rules out a bad connection?
Problem with old patchs for nokia, with nokia 3200 and 3220 v03.60 - dead phones!!! DJiCE Universalbox 14 06-14-2007 15:18
Help with sorting out a nokia 3220!! newbie robbie9911 UFS2 + UFS3-Tornadoflasher 5 06-10-2005 13:08
I Can'T Flash Nokia 3220 With Twister flechazo Twisterflasher 6 04-08-2005 14:51
Help with Nokia 3220 stanimir_13 UFS2 + UFS3-Tornadoflasher 2 03-25-2005 15:36
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.36241 seconds with 8 queries
