01-05-2006, 08:06 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: cebu
Member: 35831 Status: Offline Thanks Meter: 4 | how to flash SE phone using twister how could i flash SE phone on my twister? when i click the GO button, msg 'conect cable to turn off mobile'. i don't quit get this msg.. have waited for 3 minutes then nothing happen. need ur expert advice guys.. thanks in advance. |
01-05-2006, 11:30 | #3 (permalink) |
Member: 35831 Status: Offline Thanks Meter: 4 | some of my friends told me that its the procedure.. something like, while the phone must be turn on then conect cable then trun off then on again. or the pne must be off then conect then on.. not really so sure whats the proper procedure. anyone have any idea? |
01-05-2006, 19:39 | #5 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
don't use the batery, the power can be suplied from the cable(red wire) click on go if nothing happen so clic on rsa. to be sure if your phone is rsa or not type *>*<<*<* then see in service menu, if your phone is R6a or R7a this mean that it's rsa and u can boot it by RSA button. note: the rsa phones wust be flashed in any operation u wanna do, cause when u boot them the phone become dead automaticly, but don't worry it will be revived by flashing it. good luck | |
01-05-2006, 20:46 | #6 (permalink) |
Junior Member Join Date: Dec 2005 Location: Manchester UK
Member: 214687 Status: Offline Thanks Meter: 1 | Very important: 1) Battery must be fully charged. 2) Phone must be turned off. 3) Press go 4) Connect cable If this does not work then do the following: 1) Have fully charged battery 2) Take battery out of phone 3) Connect cable to phone 4) Press go 5) Put battery in phone. br Gsm2go |
01-05-2006, 21:07 | #7 (permalink) | |
i said that u can do it by puting the red crocodile wire in the + of the batery conector, and don't use the batery at all. this is more easy. | |
01-05-2006, 21:41 | #8 (permalink) | |
Member: 214687 Status: Offline Thanks Meter: 1 | Quote:
btw this might be complicated for you, but many twister user make flash either direct or through manual boot, looks like your solution is unique to you. br Gsm2go | |
01-05-2006, 21:51 | #9 (permalink) | |
the s.e cable that came with the package of ufs has a red wire, this is a 5v suplied from ufs. so don't put and unput the batery everytime when boot stops, just plug the cable, atach the red wire to the + oh the phone batery conector and do what u want. try it and post result b.r | |
How to flash SE phones using cruiser pro | phone2world | Sony Ericsson | 5 | 03-05-2010 15:34 |
how to flash se with cruiser use dcu 60 cable | gnscr76 | Cruiser Suite | 5 | 07-03-2007 20:46 |
how to flash se phones | phpl | HWK | 0 | 03-27-2006 14:47 |
How to flash SE phone using UFSx??? | tuandt2 | UFS2 + UFS3-Tornadoflasher | 1 | 08-19-2005 18:20 |
how to unlock SE p910i with twister? | chotky | Twisterflasher | 8 | 03-27-2005 15:06 |
