03-29-2004, 22:05 | #1 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Germany , Bavaria Age: 45
Member: 37125 Status: Offline Thanks Meter: 19 | Problem with Flash DCT-3 / 3310 I flashed a Nokia 3310 with the Twister and DCTx-Tools 1.2n . But after Flashing it would come this Error Message: M-BUS ERROR: 1F 00 10 40 00 04 00 01 64 03 01 2C BAD MOB ACK What is this ? And what can I do to solve the Problem ? Thank You For Help |
03-30-2004, 11:16 | #3 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
1.2n is allready in Twistersuite 1.16 included. I think it is a cable problem. Also check that the flashing speed is set on NORMAL, not on FAST. | |
03-30-2004, 14:00 | #7 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | Quote:
solution was posted on this section. | |
03-30-2004, 14:44 | #8 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | I`ve solved this problem. It was a Cable Problem. But i've got a new problem: The Mobile Phone get on and after 20-30 seconds it will reset. I flashed the Phone and set Faid over 10x, but it doesn't help !!! What can I do ? Before I flashed the Phone it will worked 100% !!! Thank You |
03-30-2004, 15:18 | #9 (permalink) | |
@ misterx_gsmfree you should calculate FAID again, i think this is the problem why reboot | |
03-30-2004, 16:06 | #10 (permalink) |
Member: 14279 Status: Offline Thanks Meter: 35 | maybe the extention was done by saras...but it was your ideea and u forced him to make this half working adaptor don't forget to remember your *******rs that this "adaptor" was needed so that u can use same set of cables for selling twister, griffin and prodigy clone. in this way you cut your production costs at the expense of your coustumers trust. i suggest u anytime u post about this cables problem (especialy on dct 3 phones) to remind your coustmers about this little detail. i am sure they will understand that u just tried to earn some more money. or do they PS. Sollution to get read once and for all from this "SF" adaptor is in this section. picture attached too. people who got bored to see their twister not working can use it at their own risk but i bet they will be verry satisfied afterwards. Best regards, Alin |
03-30-2004, 21:51 | #11 (permalink) |
Member: 37125 Status: Offline Thanks Meter: 19 | I`ve seted FAID 10x , but nothing the Mobile Phone has the same Problem !!! I've connected with normal MBus Cable to the Phone and use KNOK Software to make a Full Factory Reset and the Problem was solved. I think the Twister Software has an Error, the Software can't make a Full Factory Reset. The problem with reseting was solve by using a other Software (KNOK) and a normal M-Bus Data Cable. But Thanks for help !!! |
03-30-2004, 23:21 | #12 (permalink) | |
Guest
Posts: n/a
Member: | Quote:
Each adaptor need reworking, or there is no chance to boot/detect phone. It's a shame that this part which is cost less than 1 usd causing problems to this very good designed box and software. I hope you'll understand this, this is nothing against you, this is friendly advice. Do something with this adaptor, and your customers wil have less problems. Because of this CHEAP component, DCTx software fails while connected on twister, which is not case with Tornado. @MisterGsm. . . There is NOTHING wrong with software. | |
03-31-2004, 02:20 | #13 (permalink) | |
Saras WANTED THIS ADAPTOR !!! and not me. I just did what he said. He is using exact same one and he have no problems. | |
03-31-2004, 07:35 | #14 (permalink) |
Member: 14279 Status: Offline Thanks Meter: 35 | Cmon Raskal....why u try to thow the fault on someone elses shoulders? U know the reason of this adaptor...is same as i described it: U WERE GREEDY. |
03-31-2004, 07:58 | #15 (permalink) | |
Alinus sometimes i ask myself how far can go your stupidity?! I am really confused, you either don't konw the meaning of the word GREEDY or you are really totaly stupid. The plastic adaptor have nothing to do with GREEDY. | |
Problem with flashing dct-4 after mcu error I try with few phone !! !! | wgmmmx | Universalbox | 1 | 06-28-2007 14:56 |
problem flashing dct 3 with tornado & prodigy | ychoong | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 11-21-2004 20:35 |
Flash DCT-3/4 Calculator with Griffin into phone... | byteforce | Griffin | 13 | 04-12-2004 03:22 |
Problems with flashing 3310 4.35 | laxxe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-30-2001 22:11 |
