Phone Startup failed in 3650 using twister ....i apply "Full factory default" and my phone is in "Phone startup failed" condition....... i flashed it so many times but same condition......before using twister function"Full factory default" it was working perfect...help me what should i do to recover my phone back into its working position |
Format user area and your problem will go |
WD2 boot far too slower then DCT 3 and 4. If you got 6600, flash the PPM again. |
after flashing try to manually check set full factory setting do not use init file then openline and format users area. try to del. system file in memory card using mmc reader/writer after formating your fone |
If nothing helps, use China combo flash solution!! It helps me all the time when nothing else is working:) Regards Mali |
problem solve using griffin with 3650 modified cable...... Raskal i dont want to degrade ur product....i like ur twister and already purchased 5 pieces ...... but griffin is old product and its senior....i admit the power of twister but experience comes after some time....i hope twister will be more powerfull than griffin |
