PROCEDURE HOW TO UNLOCK P910/P910i 1.remove the rsa protection now the phone are dead do not remove the cable 2.init locks 3.flash the mcu now phone unlock.. note.. after unlocking p910/p910i and the key pad are not working just flash the pda area it will ok 100000% tested HOW TO REMOVE 4LOCKS CLOSED 1. INITLOCKS 2. INIT INIT SECBLK copy the serial # in the phone now phone unlock .................................................. ....... BR LEMOR |
I have unlocked 1 P910 i: Removed RSA Init locks Restore RSA Phone its ok.Unlocked,keypad working,no flashing needed. |
br lemor |
P910_R3E008_162042_RsaOn.bis or P910_R3E008_NotCertified.bis |
Use this as always : P910_R3E008_162042_RsaOn.bis or |
I have SE T230 that the 4 locks are closed how can I unlock it ?? BR snowhite |
@snowithe Flash Gdfs (untick protected Sercurity area) after flash gdfs disconnnect Phone and connect again. Press init secblk (enter otp imei) check phone 4 locks closed? if Yes reboot phone again and press initlocks this solved all my problems with 4locks closed. BR MAybe |
what software are we goin to use since twister doesnt support this fone models for now |
i did that now set is dead Quote:
i did that with p910i as ur way but set goes to be dead any solution? reply soon |
@mas comm flash the mcu part of the phone with P910_R3E008_162042_RsaOn.bis. good luck! |
IMEI on p910 ? Hi to all! Does anyone know how to change IMEI on SE p910? Could it be done wit DIVLPT + terminator ? Thanks in advance for any help. Regards, Dejan |
If u ve got the same version of MCU THEN no need to flash it again. Most important is .. when soft demands for the recovery file.. give path to that exact MCU file only. So bfore unlocking verify that u ve got that file already on ur hdd. Else first download and then proceed. REGARDS ps: look at here - just posted the elaborating pic http://forum.gsmhosting.com/vbb/showthread.php?t=194612 |
hi to all whats this error Mcu_Id: 5B 08 02 01 FF FF FF FF Certificate Error 2: 46 32 AA 01 Certificate Rejected: 46 32 AA 01 Certificated Boot Failed, 00:11 |
@elco hey man i tried to unlock a p910i the same way u did and it had asked me for a file when i tried to remove the rsa. fact is i didnt have the filke and now the phone wont power up. what can i do in terms of reviving the phone. could u help me out with some flash files. does the p910i have gdfs area. i would appreciate any help that u can give. |
