Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 04-18-2005, 07:16   #16 (permalink)
i_seeque's Avatar
Member: 15238
Thanks Meter: 127
Originally Posted by jesto80
hey man i tried to unlock a p910i the same way u did and it had asked me for a file when i tried to remove the rsa. fact is i didnt have the filke and now the phone wont power up. what can i do in terms of reviving the phone. could u help me out with some flash files. does the p910i have gdfs area. i would appreciate any help that u can give.
i think you dont need to play with GDFS area.
Simply try to recall which MCU version was having in that p910i AND flash that particular file with ufs/twister.
IF u cant recall the exact MCU file version then FLASH it with any RSAon type MCU file.
I hope u gonna revive your handset.
Old 04-18-2005, 08:18   #17 (permalink)
Member: 87998
Thanks Meter: 11
Can U Say Where I Cant Get Some P910 Files. I Would Appreiate That. How Do I Get A Response Form The Phone. I Am Using The Sara Software With The Alpha Black Box. When I Press Go The Phone Doesnt Response. So I Am Thinking The Battery Maybe Weak. I Have Put The Phone To Charge And Will Post The Result Tomorrow. What Country R U From Man?
Old 04-19-2005, 18:58   #18 (permalink)
Member: 87998
Thanks Meter: 11
Smile
i once agin tried with the p910i but i must say I am nt getting any response from the phone. I connected the phone to my alpha black box which uses sara software and pressed go but nothing happens. i got a boot failure. can any one can help me?
Old 05-06-2005, 20:09   #19 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
Originally Posted by lemor
1.remove the rsa protection now the phone are dead do not remove the cable
2.init locks
3.flash the mcu
now phone unlock..
note..
after unlocking p910/p910i and the key pad are not working just flash the pda area
it will ok 100000% tested
HOW TO REMOVE 4LOCKS CLOSED
1. INITLOCKS
2. INIT INIT SECBLK copy the serial # in the phone
now phone unlock
LEMOR
Hi,
Can you please explain better what to do in case of 4 lock in P910i.
I have one phone which could not unlock.
Thanks
Old 05-11-2005, 22:21   #20 (permalink)
Member: 78236
Thanks Meter: 3
Bad Unlock!!!
I unlocked one p910! R4B002 CXC162042
Remove RSA,
init locks,
flash MCU with file P910_R4A006_162042_RsaOn.bis
The phone now is dead.
How could I fix this problem???
Old 05-13-2005, 11:15   #21 (permalink)
I_sumo's Avatar
Member: 38103
Sonork: 100.100782
Thanks Meter: 165
Remove RSA,
init locks,
u ve downgraded your ph. It is not the wise thing you ve done.
I suggest you to first download the file: p910! R4B002 CXC162042
AND flash your phone it with.
Regards
Old 05-20-2005, 09:02   #22 (permalink)
moonmoon8's Avatar
Member: 144944
Thanks Meter: 53
Hello MAS_COMM... i have PDA Flash and i Flash On P910i its Alive Fone Again... U Mey Also Do This Methode... And I Am Also From Pakistan... Which Place of Pakistan u r From? Me From Lahore... Reply me Here or in my Mail Box [email protected] Take Care BYe
Old 05-30-2005, 05:48   #23 (permalink)
Member: 78236
Thanks Meter: 3
Luckily I revived my P910i now with the same software version that killed it. Thanks 4 advice.
Old 05-30-2005, 11:01   #24 (permalink)
JC_BY's Avatar
Member: 59319
Sonork: 100.1606948
Thanks Meter: 81
Please Help me I can't find the file P910_R4B002_162042_RsaOn.bis. Could you send it to my mail [email protected] or attach here.
Thank you for advanced.
Old 09-18-2005, 21:49   #25 (permalink)
btl
btl's Avatar
Member: 50389
Thanks Meter: 36
where can i get the mcu for p910i as mine is dead after removing rsa
thanks for ur quick response
Old 09-19-2005, 18:19   #26 (permalink)
Member: 104876
Thanks Meter: 5
Hi
get to:
BackUp:'P910_35423500******1_lck_uns_19_09_2005_18 _18_09.sim'
and then it says invalid filename.
ideas please?
Old 09-19-2005, 18:28   #27 (permalink)
btl
btl's Avatar
Member: 50389
Thanks Meter: 36
just search the forum man or go to this link use the p910 file flash ur fone
http://www.restech.pl/upload/index.php?
br
Old 09-19-2005, 18:55   #28 (permalink)
Member: 104876
Thanks Meter: 5
I have done a search (how do you think I got to post here?), I already have the correct flash file exactly as described in this thread.
Old 09-19-2005, 19:06   #29 (permalink)
Member: 136598
Thanks Meter: 3
i used the procedure listefd and it failed i read another procedure which worked fine, i removed rsa then rebuilt imei it then said remove cable and i then pressed go and then unlocked the phone then i reflashed the mcu and its workign fine now unlocked
Old 09-19-2005, 19:32   #30 (permalink)
Member: 104876
Thanks Meter: 5
I dont get that far though .. as soon as i get to
it says invalid filename .. I am presuming windows does not like the name that twister is trying to save ( the backup) somehow.
I may install a previous version of twister as I have not had this problem before.
Edit: Sorted by rolling back to a previous version.
Cheers anyway.
How to unlock P910 zeerik Sony Ericsson 3 06-26-2009 21:09
how to unlock p910 shahzad-0004 UST Pro II 5 12-03-2007 12:23
how to unlock P910? excelpass UFS2 + UFS3-Tornadoflasher 8 07-04-2005 15:41
Page generated in 0.20154 seconds with 9 queries
