Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 03-01-2004, 20:36   #1 (permalink)
Member: 38276
Thanks Meter: 35
Unhappy samsung a400 flashing problem
i tried to flash a samsung a400 but i only get this message:
"MCU_1 File: Ga40wuk4.bin CheckSum: 5EE72FBE
1st Boot Ok, Id: 0x11, 0x13
2nd Boot Ok, Version: 1.14a (May 29 2001)
Flash Erasing Failed"
-cables are ok( i tested every wire)! unlocking is working fine, just flashing not!
what is wrong???
Old 03-01-2004, 22:36   #2 (permalink)
XisiX's Avatar
Member: 37090
Thanks Meter: 42
Beta software maybe...
Old 03-01-2004, 22:54   #3 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,032
what is wrong???
@dantetimoc,
Do you have the battery attached? If so, try it again without.
Odia.
Old 03-02-2004, 18:24   #4 (permalink)
Member: 38276
Thanks Meter: 35
i tested with and widhout battery... flashing not work
tnx for reply!
Old 04-21-2005, 21:12   #5 (permalink)
Member: 50261
i am having same problem too, read info: ok, unlock: ok, but flashing not, as i can see it`s a very old bug, i hope it will be fixed in the next release of twister_sam.
Old 04-22-2005, 23:22   #6 (permalink)
Leshy's Avatar
Member: 70069
Thanks Meter: 5
you can take a loader for a400 from Optiflash and put it to Twister Suite , i have try it and it work
Old 04-23-2005, 11:46   #7 (permalink)
Member: 50261
can you please tell me which file is a loader for M46 or specificly for a400, i tried copying all loader files from optiflash 4.51, but no luck, and also can you tell me which versions of twister_suite and optiflash were you using, or even better you could even attach here the loader file your were using I think this would help for many of us
Old 04-23-2005, 23:35   #8 (permalink)
Leshy's Avatar
Member: 70069
Thanks Meter: 5
Sorry ,it was my mistake ,i had take a root.s37 file from original A408 flash pakage i give this file now
Old 04-24-2005, 14:43   #9 (permalink)
Member: 50261
Thanks Leshy it worked just fine
samsung A400 network problem...... segun Samsung Hardware Repair 2 05-21-2005 15:00
A400 flash problem griffith VLSI, Conexant, Skyworks and Old Models 3 03-23-2004 11:20
Samsung A400 flash with russian needed sat VLSI, Conexant, Skyworks and Old Models 1 01-22-2003 01:16
samsung a300 flash problem cs55 VLSI, Conexant, Skyworks and Old Models 7 12-08-2002 13:56
samsung A400 flash daro VLSI, Conexant, Skyworks and Old Models 1 02-15-2002 10:06
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.25140 seconds with 9 queries
