SE T630 Problem after Unlock with Twister Hello I have There 2 piece of SE T630 ver. R7A011 after Downgrade With Twister On R6C005 Phone dont have acess on Network .... so if somebodey have some expirience please help ..... I try to Flash New AVR+ARM+GDFS same try Other ver. soft but same IMEI is OK ...... REgrads mario |
@Jankovic Did you untick "protect SA" ? If not then it will not flash all of the GDFS area .. Dunno if it will help but it is worth a try. PS. If you flash without protecting SA please remember to give the phone it's own serial back using "init secblk" Twisterfan |
Hi Quote:
I Untick Protect SA and after that i use "init secblk" but same Thanx Mario :D |
@Jankovich Weird... Only thing i can think of is if they for example changed the RX/TX chip to a new kind that is only supported by R7 software.. Have seen sometimes in Nokia that they say that from a certain hardware revision you must use at least a certain software version because they had changed to a new chip or display that needed a "driver" only found from a certain software version ... Have never had a R7 phone in my hands but what was the reason to downgrade ?? (Is it not possible to unlock phones with software R7 ?) Twisterfan |
These is software problem....100% because the new T630 PCB ic like PA is different with old one, try to get a new file in UFSX site..maay be it can help.. I saw someone using Tornado to solve it, but they not telling me what files to flash. |
well. i had a few t630 here with r7. just used td and flashed with r6c. worked ok. then i upgraded to r7 and worked even better;:) hehe seems that td is still the best tool for old semc. br fedjak |
Hey Hello Thanx For Quick Answer And Explanation I Unlock xxxxxx Piece Of R7 With This Flash and on this way Without any Problem But I dont Know What Happend now All is Same Same Box PC Cable just Other Phones :D I little Confused dont have Idea any More .... :confused: Regrads mario |
Simple solution, find someone with best tool called Cruiser/Fighter and flash phone with version R7A011 ;) wbr. |
But can make criuiser this damage with network or only can't repair after another software? Did work old solution for this phone with UFS and TP? wbr. |
Hey Quote:
Do You Have repair Solution or ??????? Can You share with me and Other member with same Problem REgrads mario :D |
Hi Can someone please tell me why it is that Twister cannot flash version R7 ?? Twisterfan |
Tried to write new Security area, gdfs, and default calibration values but problem is the same! Any idea what to do!? BR |
I still didn't manage to repair that phones!! BR |
