Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 02-21-2005, 17:50   #1 (permalink)
Member: 93842
Activation problem on 90xxx
Hi there,
I got a new Twister 90xxx from my reseller.
I have installed the 1.30 come with the box but no luck... All four programs refuse to work
What's more is, as shown in the attachment, my s/n shown in the text area is DIFFERENT from the one shown in the status bar below~!
What's wrong??? Please help....
Thanks....
Old 02-21-2005, 18:08   #2 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,043
Please download update 1.30.001 and this will cure the issue with DCTx.
Download the Test versions of RTP and ATRz from www.twisterflasher.com/files, to cure the issues with these software.
Dont worry about the serials being different this is just a display issue with the older softyware versions which cannot handle the new serials above 65536.
Odia.
Old 02-21-2005, 18:12   #3 (permalink)
Member: 563
Thanks Meter: 22,328
Hi there,
Thanks....
and after you do what odia said, you will need activation strings, please use the one below:
Nr: 90643
EriN: 01279FD3BD69AA85FB
DctN: 05A47B7F0EFE2EA30F
SamN: 0CF1EFCA3B36DBE809
MoaN: 06F4BCAE78F553121A
Old 02-21-2005, 18:28   #4 (permalink)
todoportable's Avatar
Member: 115106
Thanks Meter: 4
Hello Raskal
Today arrived my twister from Movilcom , I have the same problem .
Nr: 90643
that you writte is for all twister? or each serial number have different one .
Thank and regard
Old 02-21-2005, 18:43   #5 (permalink)
Member: 18701
Thanks Meter: 52
Each Twister have own Serial Number and for this Serial Number you need own Activation Strings.
This Strings can give your Reseller.
regards,
Benny
Old 02-21-2005, 18:53   #6 (permalink)
MovilCom's Avatar
Member: 8959
Thanks Meter: 8
Originally Posted by todoportable
Hello Raskal
Nr: 90643
Thank and regard
Your twister dont need any activation string, please download latest software 1.30.01 and ATR & RTP software
Best Regards
Tomas - MovilCom
Old 02-21-2005, 18:58   #7 (permalink)
Member: 93842
Done~!
Thanks everyone~~!
Old 02-22-2005, 02:10   #8 (permalink)
Member: 115106
Thanks Meter: 4
Best Regards
Tomas - MovilCom
thank you very much Tomas
Best Regard
Old 02-22-2005, 13:18   #9 (permalink)
MovilCom's Avatar
Member: 8959
Thanks Meter: 8
Remember if serial number of your twister is 90xxx
usually you dont need any activation string,
Please dont run any older software
and dont put any activation string
Best Regards
Tomas - MovilCom
Old 02-22-2005, 15:11   #10 (permalink)
Member: 115106
Thanks Meter: 4
Dear Tomas
I think , the 1st one that buy I have problem , because when I try to conect in Nokia softyware itīs said BOX_AUTH_ERROR:32 , and i cant flash anything . I have talk to many friend , itīs could be activation problem ?
The 2nd one works great , Twister is fantastic ( I only need LOGGIN & PASSWORD of the support area ) .ī
Thank you for your support
Best Regard Carlos
Old 02-22-2005, 16:11   #11 (permalink)
TheMasterGSM's Avatar
Member: 73387
Thanks Meter: 18
Red face
hello,
i have my activation code .but when i enter i get this message
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0
UFS_USB V2.6 (c) SarasSoft 2005.S/n: 25099
Licence: False
Licence Updated, Please Reconnect
if i reconnect then i get the same message again!!!
For nokia it is working!!
please any help??
thanks
Old 02-22-2005, 17:49   #12 (permalink)
MovilCom's Avatar
Member: 8959
Thanks Meter: 8
Dear Tomas
Best Regard Carlos
MAN !!!!!
I WROTE WITH BIG LETTERS on the paper INSIDE PLASTIC BOX
NEVER PRESS UPDATE BOX without previous(before) notice.
Do not press on the button "update firmware" - you will deactivate the box.
Spanish Version:
No actualizar la box, sin previo aviso.
Esto es, no pulsar sobre el boton "update firmware" en la pestaņa UFSx del modulo de Nokia DCTx o descactivareis la caja.
PLEASE READ MANUAL BEFORE START TO PLAY WITH YOUR BOX !!!!!!!!!!!!!!
Best Regards
Tomas - MovilCom
P.S.
For repair your first box :
1. Go to Archivos de programa/Nokia/Phoenix
2. Delete File 90026.req
3. Connect "bad" box. Run Software "DCTX 1.3i"
4. Press "Update BOX"
5. Select REQ.FBI file
6. When Software ask you "you are sure" press "YES"
7. WHen Software terminates you will see message "req file saved in ......"
8. Disconnect box, from cable.
9. PUT IT in the booth (DONT TOUCH IT BEFORE RECEIVE NEW FILE)
10. Go to Archivos de programa/Nokia/Phoenix
11. Compress file 90026.req
12. Send this file to [email protected]
13. Will send you "NEW FILE" when we receive it from SARAS
Old 02-22-2005, 22:28   #13 (permalink)
Member: 115106
Thanks Meter: 4
Soory Tomas , If I did a mistake , Iīve already send you a mail , sorry
Old 02-25-2005, 02:25   #14 (permalink)
Member: 115106
Thanks Meter: 4
Now I have problem with XYY34 box , when I use Eric_ATR_Ufs_16i_test2.exe and Eic_RTP_Ufs_26i_Tst_2.exe , When I conecct it , the box ask me for the activation string .
UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 0 0
Licence: False
Licence Update Failed
thank you very much & regard Carlos
Old 02-25-2005, 08:24   #15 (permalink)
Member: 739
Licence: False
hmm i am looking on your desk in the background LOL i think you should not have all that Stuff there becuase it will be a big memory slowdown there lololol..
And for the problem you have now you need to update the license and need a activation string key.
Ask your reseller he will help you to give you those strings.
/Gsmhq
activation problem on lg azeezat Xpresscodes.com 2 06-28-2009 10:33
activation problem on lg azeezat Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 06-28-2009 00:14
problem on activation bb5king azeezat BB5KING for (BB5BOX) 2 11-04-2008 21:52
problem getting activation email on gsmserver.com theonlyallan Smart-Clip 3 10-18-2006 17:09
Problem on Activating phone... jacsha Cruiser Suite 9 05-10-2004 19:21
Page generated in 0.33549 seconds with 10 queries
