Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 11-22-2019, 17:32   #1 (permalink)
ataman's Avatar
Member: 38921
Thanks Meter: 16
A405FN not charging
need solution for A40 not charging
The Following User Says Thank You to ataman For This Useful Post:
Old 11-22-2019, 18:09   #2 (permalink)
Member: 2778749
If you have microsoldering knowledge than check the small board for shorts. If not change the small board there is the problem.
Sent from my SM-G950F using Tapatalk
Old 12-01-2019, 22:02   #3 (permalink)
Member: 9584
Thanks Meter: 31
i ve the same Problem i changed the small charging platine but it is the same
Old 06-10-2020, 18:45   #4 (permalink)
Member: 154346
Thanks Meter: 37
any solution for this problem
Old 06-23-2020, 16:07   #5 (permalink)
bossko's Avatar
Member: 17761
Thanks Meter: 91
have same problem. I change small USB board without success
Old 07-16-2020, 14:53   #6 (permalink)
Member: 618610
Sonork: 69665
Thanks Meter: 8
Hi i fixed with rehot u5001 and U7000
now its worging, but first check the connector pcb
The Following 2 Users Say Thank You to stewe1 For This Useful Post:
Old 09-02-2020, 15:21   #7 (permalink)
Member: 49046
Thanks Meter: 25
lt's worked ! thanks
Page generated in 0.17488 seconds with 9 queries
