02-27-2017, 14:01 | #1 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 232487 Status: Offline Thanks Meter: 53 | Samsung S4 Mini GT-i9190 not working |
02-28-2017, 14:13 | #5 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1921245 Status: Offline Thanks Meter: 43 | I have many s4 mini with this problem, first you have to check for shorts, reball pmu to be sure and start with oscillators, if not then it's flash memory problem, If anyone has experience, I al Also waiting for new flash to test and I will post Sent from my iPhone using Tapatalk |
02-28-2017, 22:02 | #6 (permalink) |
No Life Poster Join Date: Oct 2012 Location: italy
Member: 1825965 Status: Offline Thanks Meter: 874 | hi from my experience the problem is nand. need a reball. i had already replaced pmic but at the end was the nand. ps @xxemoxx no need to write a lot of posts have to wait for someone to answer you |
03-03-2017, 18:17 | #7 (permalink) |
Member: 232487 Status: Offline Thanks Meter: 53 | Hi friends. I tried rehot power ic but still same problem. I changed nand. I have cnc and all pinouts perfect. Still same problem. Tapatalk kullanarak iPhone aracılığıyla gönderildi |
03-05-2017, 10:48 | #9 (permalink) |
Member: 1921245 Status: Offline Thanks Meter: 43 | Did you manage to replace it ? I always damage the pads on the pcb trying to remove this EMMC on s4 mini... I think that changing the make of the emmc is not a problem because you will flash it again and phone with connect with the new emmc. Sent from my iPhone using Tapatalk |
