A800 Call Failed Problem!! Hi i had a Samsung A800 given to me that wouldnt allow me to make calls, so i changed the IMEI on it. Now when i put an O2 sim it works fine but when i insert an Orange sim i try making a call and then it says CALL FAILED. What can i possibly do now??? |
I have solved one by full eep reset *2767*2878# you don't lose nothing if you try b.r. |
check if the IMEI is correct first ! if the code gave by THECULT doesn't worke try to rehot RF part espacially PA an mixter !!! |
1. check your new imei of your phone ,first. 2. you can reset your phone call barring operation, thru phone menu. try this operation before any thing . bestman. |
try this try removing the components that are specified in the following post:http://forum.gsmhosting.com/vbb/showthread.php?t=135168 then rewrite a new eeprom and unlock it, chek ur batt`s a800 |
:) you have lucky, petermov is here hehehe |
