01-09-2006, 21:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 45
Member: 166746 Status: Offline Thanks Meter: 86 | Soldiering LCD's onto flexis / flats. best way / tips please??? -urgent- I am having some trouble removing lcd's that are soldeired from the pcb or placing new ones onto pcb which need soldiering, for eg.: The E700, i want to remove the big n small lcd from damaged flex/flat cable and place it onto new flex cable, What is the best way to remove / replace the lcd to and from new old cable. Another eg. I want to change C100 samsung LCD, i tried with air gun and with sodlier iron, sometimes its messing up. please advice soem tips ;> |
01-15-2006, 19:03 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: New York City, USA Age: 58
Member: 56365 Status: Offline Thanks Meter: 28 | Yes would be appreciated also. It took me two tries to replace R225 lcd to pcb board. Not fun, and luckily it was cheap lcd not expensive new model. I had taped it in place then solder one line on each end to keep it straight. Looks easy but is not because lcd connector is very sensitive. Regards, JOHNNY. |
01-30-2006, 07:20 | #4 (permalink) |
Junior Member Join Date: Sep 2005 Age: 41
Member: 183723 Status: Offline Thanks Meter: 0 | u can use hot air with decent heat and low air to take out LCDs. move it slightly from beginning of flat to the middle ,when u see it is the time try to take it out carefully from the outer side and and continue using hotair slowly to the end. |
03-04-2006, 08:35 | #6 (permalink) |
Member: 166746 Status: Offline Thanks Meter: 86 | I managed to remove E700 lcd from flexi cable and put it onto new cable the large lcd works 100% but the small lcd i fitted 3 new ones, it jsut wont display even with magnet in place... any ideas??? |
2310 charging ways please urgent | meeru | Nokia Hardware & Hardware Repair | 6 | 07-27-2013 11:02 |
SonyEricsson K510i ON/OFF Ways Picture........Very urgent please | repmob | Sony Ericsson Hardware Repair | 0 | 01-14-2009 16:06 |
G1500 power switch ways & led ways needed............plz....urgent | smgujar | LG | 0 | 08-21-2007 15:24 |
Best way to install Fighter onto XP | Mastah-GSi | Cruiser Suite | 11 | 03-13-2005 19:31 |
Best way to unlock my T18, please HELP!!! | Husocan | Old Ericsson Phones & Sony Phones | 5 | 09-25-2000 01:20 |
