10-20-2007, 05:41 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | SAMSUNG Code for sumsung *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*289# : Change Alarm Buzzer Frequency *#9998*324# : Debug screens *#9998*364# : Watchdog *#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok. *#9998*427# : Trace Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*544# : Jig detect *#9998*636# : Memory status *#9998*746# : SIM File Size *#9998*778# : SIM Service Table *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*786# : Run, Last UP, Last DOWN *#9998*837# : Software Version *#9998*842# : Test Vibrator - Flash the screenligth during 10 seconds and vibration activated. *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*872# : Diag *#9998*947# : Reset On Fatal Error *#9998*999# : Last/Chk *#9998*9266# : Yann debug screen (=Debug Screens?) *#9998*9999# : Software version If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0002*?# : unknown *0003*?# : unknown SP-unlock SGH-600 (and also SGH-Sgh-600) *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 for d500 *#11[quote]11# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together *#8999*8378# Test Menu *#4777*8665# GPSR Tool *#8999*523# LCD Brightness *#8999*377# Error Menu *#8999*327# EEP Menu *#8999*3825523# Don't Know. *#8999*667# Debug Mode *#92782# PhoneModel (Wap) #*5737425# JAVA Mode *#2255# Call List *#232337# Bluetooth MAC Adress *#5282837# Java Version #*4773# Incremental Redundancy #*7752# 8 PSK uplink capability bit #*7785# Reset wakeup & RTK timer cariables/variables #*1200# ???? #*7200# Tone Generator Mute #*3888# BLUETOOTH Test mode #*#8999*324# ?? #*7828# Task screen #*5111# ?? #*#8377466# S/W Version & H/W Version #*2562# Restarts Phone #*2565# No Blocking? General Defense. #*3353# General Defense, Code Erased. #*3837# Phone Hangs on White screen #*3849# Restarts Phone #*3851# Restarts Phone #*3876# Restarts Phone #*7222# Operation Typ: (Class C GSM) #*7224# !!! ERROR !!! #*7252# Operation Typ: (Class B GPRS) #*7271# CMD: (Not Available) #*7274# CMD: (Not Available) #*7337# Restarts Phone (Resets Wap Settings) #*2787# CRTP ON/OFF #*2886# AutoAnswer ON/OFF #*3737# L1 AFC #*5133# L1 HO Data #*7288# GPRS Detached/Attached #*7287# GPRS Attached #*7666# White Screen #*7693# Sleep Deactivate/Activate #*7284# L1 HO Data #*2256# Calibration info? (For CMD set DEBUGAUTONOMY in cihard.opt) #*2286# Databattery #*2527# GPRS switching set to (Class 4, 8, 9, 10) #*2679# Copycat feature Activa/Deactivate #*3940# External looptest 9600 bps #*4263# Handsfree mode Activate/Deactivate #*4700# Please use function 2637 #*7352# BVMC Reg value (LOW_SWTOFF, NOMINAL_SWTOFF) #*2558# Time ON #*3370# Same as 4700 #*3941# External looptest 115200 bps #*5176# L1 Sleep #*7462# SIM Phase #*7983# Voltage/Freq #*7986# Voltage #*8466# Old Time #*2255# Call Failed #*5187# L1C2G trace Activate/Deactivate #*5376# DELETE ALL SMS!!!! #*6837# Official Software Version: (0003000016000702) #*7524# KCGPRS: (FF FF FF FF FF FF FF FF 07) #*7562# LOCI GPRS: (FF FF FF FF FF FF FF FF FF FF FF FE FF 01) #*2337# Permanent Registration Beep #*2474# Charging Duration #*2834# Audio Path (Handsfree) #*3270# DCS Support Activate/Deactivate #*3282# Data Activate/Deactivate #*3476# EGSM Activate/Deactivate #*3676# FORMAT FLASH VOLUME!!! #*4760# GSM Activate/Deactivate #*4864# White Screen #*5171# L1P1 #*5172# L1P2 #*5173# L1P3 #*7326# Accessory #*7683# Sleep variable #*8465# Time in L1 #*2252# Current CAL #*2836# AVDDSS Management Activate/Deactivate #*3877# Dump of SPY trace #*7728# RSAV #*2677# Same as 4700 #*3797# Blinks 3D030300 in RED #*3728# Time 2 Decod #*3725# B4 last off #*7372# Resetting the time to DPB variables #*7732# Packet flow context bit Activate/Deactivate #*6833# New uplink establishment Activate/Deactivate #*3273# EGPRS multislot (Class 4, 8, 9, 10) #*7722# RLC bitmap compression Activate/Deactivate #*2351# Blinks 1347E201 in RED #*4472# Hysteresis of serving cell: 3 dB #*2775# Switch to 2 inner speaker #*9270# Force WBS #*7878# FirstStartup (0=NO, 1=YES) #*3757# DSL UART speed set to (LOW, HIGH) #*8726# Switches USBACM to Normal #*8724# Switches USBACM to Generator mode #*8727# Switches USBACM to Slink mode #*8725# Switches USBACM to Loop-back mode #*3838# Blinks 3D030300 in RED #*2077# GPRS Switch #*2027# GPRS Switch #*0227# GPRS Switch #*0277# GPRS Switch #*22671# AMR REC START #*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr) #*22673# Pause REC #*22674# Resume REC #*22675# AMR Playback #*22676# AMR Stop Play #*22677# Pause Play #*22678# Resume Play #*77261# PCM Rec Req #*77262# Stop PCM Rec #*77263# PCM Playback #*77264# PCM Stop Play #*2872# CNT *#8999*283# ??? #*22679# AMR Get Time *288666# ??? *2886633# ??? *#8999*364# Watchdog Muhammad Afzal Meo |
The Following User Says Thank You to meo786pk For This Useful Post: |
10-20-2007, 05:43 | #2 (permalink) |
Member: 465162 Status: Offline Thanks Meter: 683 | more for A707 to detect as modem please follow the instruction type *#0002*28346# press 2 times back go to common(press 9 ) >>>> USB (press 6)>>>> presss 1 Muhammad Afzal Meo |
Moto Codes/Samsung Codes/Voda UK/ BB5 Rpl(unlock via rpl possible) | aj4u | Main Sales Section | 0 | 04-13-2008 20:41 |
Setool Logs/Moto Codes/Samsung Codes/Voda UK/ T-mob/ Uk/BB5 Rpl and much more | aj4u | Main Sales Section | 0 | 02-21-2008 17:41 |
I need a Account of 20 Motorola Codes and 1 Samsung Code | Grupo MovilFree | Wanted Products | 6 | 10-08-2007 06:18 |
Samsung Code Reader 3.5 - Reads A300,R200,R210... codes by EEPROM dump | aorid666 | VLSI, Conexant, Skyworks and Old Models | 6 | 10-25-2002 10:58 |
Samsung code reader v3.3 by Pago & Samsung by DUSKnenixs | evilspell | Samsung Flashers, Software, Firmware. | 0 | 11-18-2001 22:09 |
