c170 blue lcd after change charge conecter 100% solutions help i have c170 i tryed to change charge conector and display goes blue i tryed many lcd but no sucess and one had face this problem and solved plz??, |
remove charging connector and then check |
run the software for it |
ok no way !!same probelm i removed charge conector and run sowtware all ok but always blue lcd (note: i can make call )any solution??? |
samsung c 170 blue display facing the same problem, i rcvd for replace the charging socket after replacing the set is dead |
remove charging jack and fix it other one carfully mr panchami good luck |
C 170 Thanks.................. Quote:
