C3303---MMC not Detected I have changed mmc slot, continuity at pins is ok still not detecting mmc. Plz tell where ic mmc ic so that problem can b solved |
So many technicians have read this thread, but no body gave solution. Plz help |
silly boy Where Is Solution ?????????? don't Misguided Member |
2 Attachment(s) Quote:
try trick picture below...i hope you succsesfull..? |
Mr d-Artigo, me tried according to u but still same problem |
tracing the mmc holder or near test point. same my problem success |
trace the memory holder pin |
bro can i help u the mmc holder have 8pin but it 9pin there so make grnd to pin n9 pin9 is the top off mmc holder |
if u don;t understand plz call me +919762091290 i will give u 10000000000% sol freeeeeee |
try this 4 c3303 mmc this is tested sol bro try n post reply me |
dear all try this.....mmc not work.....check voltage on mmc slot pin no 4....mack jumper on any resisence wear shose 2.8volt....give the voltage at pin no 4...2.8volt....i tryed....warked 100% |
c3303 mmc not worinking |
not working any other solution sirrr |
