D500 pad i have d500 its pad not working can any 1 help me with this? |
got same problem! Keyboard doesn´t work..:confused: |
check the flex ribbon, no dout it will need ti be changed |
what not working here? if it is the main keypad (123456789*0#) then please remove the back cover and check that the volume and camera keys are properly alligned fluch against the black rubber part (not pushed under it). that will cause the volume/camera key to be pressed down so no other key is respond... if it is screen board keys not work (green, red, scroll), then please check the bottom two screws in the LCD housing part. if they are over tight then these keys will fail. as always, check key pad and dome sheet for corrosion, clean if required... after this, your problem is down to processor almost for sure as keys are linked direct to there.. |
same problem i am also having the same problem the 2 5 8 0 buttons on my d500 occasionally work but other times they dont has anyone got any ideas? |
any solution for this problim? |
