d500 samsung when i connect with charging then its turnig on and when i take of the charger then its turn off i have change the flex but problem is same can u tell me whats the problem. also during the charging on of |
try to change battery or phone is shorted.... |
First make service your mobile then check charge connector. |
brother if ur battry is ok then it is % flex problem |
Re: hi, check battery, If Ok, mostly yu have shorted board. Mainly check the Power Amp Module in the RF Part (check if heated when try power on)..Also, If flex is low quality replace first. Xpert |
