03-10-2006, 19:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: work Age: 11
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | Samsung D600 (slider Problem)!!! when slide is closed and u power on fone its fine and turns on and functions normal... but-when fone is switched off and the slide is open,when u power on the fone it turns on but only with blank display!!! not white display just dark with small white borderline light!!! when u close slide the screen lights up and functions normal!!! any assistance would be most welcome and thanks in advance. |
03-10-2006, 21:45 | #2 (permalink) |
Junior Member Join Date: Aug 2002 Location: united kingdom Age: 56
Member: 14771 Status: Offline Thanks Meter: 0 | re d600 fault hi sounds to like this handset has been taken apart .???? if so then has the maganet been put back properley (ie) the right way around as this operates the function of the slide ?? also it could be the ribbon cable either not located properley or needs replaceing both these options could be your problem hope this helps robbie |
help!!unlock samsung D600!!!! | mostafa-oujdi | SWIFT Platform | 8 | 01-17-2006 23:14 |
Samsung D600 | heffdog | SWIFT Platform | 3 | 10-19-2005 06:36 |
Unlocking a Samsung D600 | gaz_0001 | SWIFT Platform | 10 | 10-09-2005 10:56 |
* Hot,hot,hot !!! Samsung D600 unlocker !!! | BB-gsm | SWIFT Platform | 18 | 10-03-2005 07:06 |
