E1085 Ringer ok speaker not working Dear sir i have E1085 Problem is speaker not working ringer is ok i changed many connector and also clean the whole pcb but problem still not solve please give me right direction to repair the phone. thanks in advance |
just replace the big speaker |
hello sir i hev a problem with samsung e1105t it hangs i hev tried flashing it can i hev a solution thanx in advance |
change charge connecteur. |
change charging conector |
risold charging conector 1000%ok |
e1085 yes its good re solder charging connecter |
not solved my problem |
not slove my speker problemm e1080 |
1 Attachment(s) Quote:
samsung gt-e1080t speaker check all component speaker L307-L308-C316-C317-D301 and D302 see image below |
i have checked every components still the same no ringer and speadker only loudspeaker works give me the solution please thanks i advance |
warms charging conector 100 % ok |
Solution 4 110f working 1000 percent thanks alot Solution for e1100f working well just warmed phone charging bloch was dirty with water |
