E720 Problem!!! Hy! I have an e720 wich power on only when i conect to ufs, after power on phone works normally exept power on\off button. what should i do? thanks! |
take your sim card out and put it bk in |
Another sugestions. |
Try to clean it. Some times it helps. If not - write again and i'll tell you what to do. |
Try to bake it and follow the button matrix on the PCB. |
Topic Close!!! Reason: Because Of Nonreal Solution To Repair This Phone And Because I Get Mad And I Burn Phone After I Drop It Down With Max Speed :d |
Topic Closed!!! Reason: Because Of Nonreal Solution To Repair This Phone And Because I Get Mad And I Burn Phone After I Drop It Down With Max Speed :d |
I have same problem .. Help ...!!!! Thx advance .... Kotogsm |
1 Attachment(s) connect V311 Rezistor's left Pin to start button external ring post results |
x660 on off problem i have x660 same problem solution please |
flash ic problem tested in many cases |
