Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-10-2007, 22:17   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::e330 internal display show blue::..
samsung e330 internal display show blue sometime display comes and outer small display is ok, i change 2 strips and strips are 100% ok.
Old 09-10-2007, 23:02   #2 (permalink)
omega-telecom's Avatar
Member: 227959
Sonork: 100.1589050
Thanks Meter: 254
change the lcd internal
good luck
Old 09-10-2007, 23:56   #3 (permalink)
mhamad-198's Avatar
Member: 437340
Thanks Meter: 35
brother change connector and chANGE FLAT FEXE
Old 09-11-2007, 03:24   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i think bcoz of these 2 tracks missing, in result blue display
can anyone trace these two tracks,thnx in advance!
Old 09-11-2007, 19:58   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
plz pay attention to this?
Old 09-12-2007, 21:27   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
where are the experts?
Old 09-14-2007, 02:48   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
such a big forum and no reply?
Old 09-14-2007, 04:04   #8 (permalink)
Member: 31028
Thanks Meter: 56
just replace the flex...
Old 09-14-2007, 05:54   #9 (permalink)
Temporary banned !!
Member: 546766
Thanks Meter: 51
it is do not need just change the flex........
Old 09-14-2007, 11:17   #10 (permalink)
tele-teknik's Avatar
Member: 64598
Thanks Meter: 54
yes just change the flex........
Old 09-14-2007, 21:33   #11 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
wat about the 2 print of display strip missing?
Old 11-20-2007, 12:30   #12 (permalink)
Member: 249837
You need to change (sometimes rehot enough) this part (in red circle). It's work. 100000%
I have already made 10 pices E330 with this problem. This is the right solution.
Old 11-20-2007, 15:27   #13 (permalink)
Member: 241277
Thanks Meter: 4
change flex
hi!change flex and everything will be ok;just take care when u will unsolder display screens(front and back) becaus easy to damaged with hot air.
if the solution does not satisfy u follow the lines u will end on for points that correspond to the 4th:6th 5th and 7th lines on tthe connector make jmpers and everything will be ok.attention this second solution is not professionnal becauz it will not last long ;good luck
TE365 vygis team help i unlock phone show only display show six colour mobispot VygisToolbox 6 08-27-2009 22:05
Nokia 7270 no internal display... sergo_zmeia Nokia Hardware & Hardware Repair 1 09-19-2005 15:30
Need mpx200 internal display invision Hardware Repair Item Wanted 0 06-02-2005 12:57
t720 no internal display steviewonder Motorola P2k 3 09-03-2004 17:23
t720i internal display-settings(flex) files needed alexzzander Motorola P2k 8 02-15-2004 11:10
Page generated in 0.19634 seconds with 10 queries
