Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 01-08-2009, 10:12   #1 (permalink)
bmm08's Avatar
Member: 464270
Thanks Meter: 56
e900 lcd problem
hi
i have a e900 that don't display,i changed the flex,the main pcb,the lcd pcb and the lcd but the problem persist only black lcd when i turn on.
Old 02-20-2009, 10:21   #2 (permalink)
Member: 514384
E900 great problem display.
I changed the Flx cable ;and the LCD bat i have the same resulte ( white display)
Old 02-27-2009, 18:51   #3 (permalink)
Black_Daimond's Avatar
Member: 179391
Thanks Meter: 57
I have same problem here, I have change flex tape, change LCD, but still LCD blank. (White screen)
Hello...!
Any solutions?
Old 06-21-2009, 13:42   #4 (permalink)
Member: 942098
i encountered this problem when i changed a e900 display... however i don't guarantee this will work ... maybe just a few will be lucky ....
Check where the flex ribbon is connected... make sure it's firmly inserted till the white little line on the ribbon is at the same level with the connector ... also check the connector for dust etc before you insert the ribbon . This worked for me but i'm not sure will work for everyone .
Old 07-27-2009, 10:50   #5 (permalink)
Member: 699304
Thanks Meter: 14
i have also here
same prob...
ill change flex...
ill check all the conection but its ok...
how we can solve this???
Old 10-28-2010, 21:02   #6 (permalink)
Registered User
Member: 616655
Thanks Meter: 3
ces 100/100 changer un petite circuit 5pat qui se trouve acote les capat sous la trap de nap merci
Heeelp e900 LCD mix after flash help me jawad8305 Trident/AGERE Platform 3 07-10-2011 22:33
Samsung E900 touchpad problem T_T thaoanthony Samsung Hardware Repair 4 10-28-2010 15:19
E900 Lcd Key Lİght And Keypad CEPHASTANESİ Samsung Hardware Repair 3 10-21-2007 09:49
Heeelp e900 LCD mix after flash help me jawad8305 UFS2 + UFS3-Tornadoflasher 2 03-31-2007 14:46
e900 unlock problem sewkar UST Pro II 12 08-11-2006 10:35
Page generated in 0.19841 seconds with 9 queries
