gsm secret codes GSM Secret Codes Type *#61# and press call - Check redirection status. Cancel all redirections: ##002# *43# to activate call waiting, to deactivate #43#. If your phone doesn't have incoming call barring and outgoing call barring, you can try this. For outgoing call barring dial *33*barcode*# and pres OK. To deactivate it dial #33#barcode*#. On any phone on any network type in **43# to enable conference calls. You can make up to 7 calls at once If you need to block SMS reception (if you are spammed by someone) just press this code: *35*xxxx*16# xxxx is your Call Barring code (default is 0000). To remove this barring type: #35*xxxx# If you want to hide/show your phone number when calling, put one of these codes below in front of the number that you are going to call. (*#30# / *#31# or *31# / #31# ) Works on some networks. Typing *0# or *nm# on the beginning of a txt message gives you detailed delivery report on some networks.. But turn off reports in message settings before. When the sim card-pin blocked type **042*pin2 old*newpin2*newpin2* Airtel Secret Codes Dial *123# to see your credit balance. Dial *110# and follow the options. Dial *109*9898631902# to display the call cost after each call. If you are in Indiausing IDEA Pre or Postpaid connection then dial *101# you will get a secret menu that will let you to activate or deactivate any supported Idea package for your mobile. Software version: *#9999# IMEI number: *#06# Serial number: *#0001# Battery status- Memory capacity : *#9998*246# Debug screen: *#9998*324# - *#8999*324# LCD kontrast: *#9998*523# Vibration test: *#9998*842# - *#8999*842# Alarm beeper - Ringtone test : *#9998*289# - *#8999*289# Smiley: *#9125# Software version: *#0837# Display contrast: *#0523# - *#8999*523# Battery info: *#0228# or *#8999*228# Display storage capacity: *#8999*636# Display SIM card information: *#8999*778# Show date and alarm clock: *#8999*782# The display during warning: *#8999*786# Samsung hardware version: *#8999*837# Show network information: *#8999*638# Display received channel number and received intensity: *#8999*9266# *#1111# S/W Version *#1234# Firmware Version *#2222# H/W Version *#8999*8376263# All Versions Together *#8999*8378# Test Menu *#4777*8665# GPSR Tool *#8999*523# LCD Brightness *#8999*377# Error LOG Menu *#8999*327# EEP Menu *#8999*667# Debug Mode *#92782# PhoneModel (Wap) #*5737425# JAVA Mode *#2255# Call List *#232337# Bluetooth MAC Adress *#5282837# Java Version Type in *#0000# on a Samsung A300 to reset the language Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710) Samsung E700 type *#2255# to show secret call log (not tested) Samsung A300, A800 phone unlock enter this *2767*637# Samsung V200, S100, S300 phone unlock : *2767*782257378# http://www.gleez.com/articles/did-yo...a-secret-codes |
I am using Nokia 6600 unlocked mobile recently i unlocked my mobile here ************.com : Unlock your mobile phone for free at free of cost and then i search secret code for my mobile... I found here now i got the secret code to my mobile...thanks..... |
