06-24-2005, 21:32 | #451 (permalink) |
Junior Member Join Date: May 2005 Location: portharcourt,nigeria
Member: 145868 Status: Offline Thanks Meter: 0 | |
06-24-2005, 22:27 | #456 (permalink) | |
Freak Poster Join Date: Jul 2004
Member: 71751 Status: Offline Thanks Meter: 3 | answer Quote:
06-24-2005, 22:56 | #457 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Quote:
1..2 3..4 |56| if u don't conect hands free 3+5 and 4+6 are in schort... so check if it is so, if not just make the short | |
06-27-2005, 12:05 | #458 (permalink) | |
Freak Poster Join Date: Aug 2004 Age: 54
Member: 80073 Status: Offline Thanks Meter: 5 | Quote:
USE EARTH/NEG FOR BOTH LINKS . SOLVES PROBLEM OF WHITE SCREEN. | |
06-27-2005, 17:26 | #461 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
06-27-2005, 17:59 | #462 (permalink) | |
Freak Poster Join Date: Apr 2005 Age: 43
Member: 138234 Status: Offline Thanks Meter: 79 | e600 audio problems Quote:
The Following User Says Thank You to MBtech For This Useful Post: |
06-30-2005, 00:13 | #464 (permalink) | |
Search with multimeter the PCB for Shortcuted Conds. after procedure i think should be the same...If cond is electrolitic you should take of, and replace, if normal cond thry remove, and if short is steel there you aply 5V 2.5A for some time till short go, and R over Cond is around 155 or more... Also there are some Diode on the bottom keypad part, try to see if there are shortcut also(beep on the the two ways)... if so you take them out, or replace them BR All this is what i think, i didn't have this problem yet All i had was one C electrolitic on botom near the 2 diodes and it was easy to see it was broke, because he was in schort and color and form change... I have replace and now phone ok... but i don't know if man have charge it with lg... | |
06-30-2005, 11:34 | #465 (permalink) |
Registered User Join Date: Aug 2004 Location: India Age: 46
Member: 77443 Status: Offline Thanks Meter: 24 | check battery voltage using code *0228# without sim screen displays voltage of batt. detected by cpu if it is wrong voltage reflash phone try again |
***All Samsung Hardware Solution*** | bunty2008 | Samsung Hardware Repair | 33 | 01-14-2020 14:10 |
All Samsung Hardware Solution | bsat | Samsung Hardware Repair | 25 | 10-13-2018 12:43 |
