Hardware Repair Series - Samsung E700-E710-E715 insert SIM Solution @All Well for quite some time I have not posted any solutions, due to alot of facts which I wont go into details on now :D Anyway today we gonna solve the E710 "Insert SIM" fault, very easy to repair. Tools needed for this fix : 1 : Soldering Iron 30 - 50 Watt with SMD tip. 2 : Good flux, I recommend ERSA - FMKANC32-005 non-clean cream. 3 : Soldering tin 1.5 - 2 mm with core flux. 4 : Thin patch wire insulated ! The problem occurs normally around the IC called U100, the function is actually power module/led driver and RS232 between the Sim Reader and CPU ! I've had too many with broken lines from Sim Reader to U100 Lets fix the bugger Here you see the area we have to work on, to find the correct leg, start from top left side of U100 and start counting counter clockwise untill you reach leg 48-49-50 and 51, you can see in this picture where the pacth wire is located so you have an idea where it is http://www.gsmcoolhawk.com/gsmforum/...E710_SIM_1.jpg On the next pic here you see the "work area" magnified to 60x. Now the red numbers corresspond to U100 leg numbers, while THIS CYAN is what legs on the SIM Reader they are connected to http://www.gsmcoolhawk.com/gsmforum/...E710_SIM_2.jpg On the last pic here you see the SIM Reader legs and their numbers, in red you have the leg numbers on U100, so just measure if you have all 4 lines ok, if not you have found the fault http://www.gsmcoolhawk.com/gsmforum/...E710_SIM_3.jpg Well thats it for this time :D More coming up soon in Samsung hardware repair area Hope this helps out some folks. Good luck, and dont blame me for busted boards, do this at you own risk ! And please, do not start any "send me too" posts of any kind, they will be deleted. I do not have it whatever it might be. For your information I use a Novex AP-8 stereo microscope, and pictures posted here is taken with a QX3 Intel (tm) digital toy microscope, you can find those nice little ones on Ebay for around 60 Euro. OBS ! Edit 16/9-2005 Solution for E700 will come as soon as I get a E700 board and can take some pictures. Power supply IC here is called U400, and have a different wirering.. And please, DO NOT start 1 line thank you posts, I WILL delete them, its waste of our server space, post only if you have anything additional which is directly related to this fault, or if you have found other solutions than this. You may rate the thread instead of posting thankyou post or you can choose to make a vote on the poll on top of this page ! Regards |
What is solution for E715 insert sim ? |
@Jani-Jan Have you opend the phone and checked if same module is used ? I've been told this solution here works on E710 also, but I do not have schematics for E715 as of yet, if anyone have, let me know by email or PM, or post in this thread here. Regards *Edit* It's now confirmed. This solution will work on the follwing models. E700-E710 and E715, all have the same U100 chip and wirering ! Regards |
1 Attachment(s) hi mr gsmcoolhawk im posted here 3 pic for e715 i hope to help any one to solv this problem |
@abbeydguru Please READ full post before you post. The name of this thread is "Hardware Repair Series - Samsung E700-E710-E715 insert SIM Solution" E715 can be repaired same way as E700 and E710, also see that I have a edit in my post just above, where it clearly states E715 can be repaired same way ! Regards |
E71x SIM reader ways 1 Attachment(s) here is shared the E71x SIM reafer ways |
Good solution tested by me and work 100%, i have good luck to have one e715 insert sim and now repaired ;) |
E700 Insert Sim Pls any Solution E700 Insert Sim. this board power i/c is U500. |
hi eko Thank's Reply yes i tried the solution aldy. but the power i/c is BGA (U 500) not same U 100. sorry my Board is E700A :confused: |
good solution for E 700 , but what about V200 any one have solution for insert SIM Solution ? Thx |
Solution will work until have not problems between power IC and Agere CPU lines :( so 90% with "user" hardware damaged SIM sockets can be maded with GSM Coolhawk solution... another 10% with break between power IC and CPU need more work. |
lol e700 not agere system and have no agere power ic. so it's not for e700 |
the same is for me.I have u500 power supply,how to make this work with u500? regards |
