help c260 hang restart set is not water damage not damage by droping.suddenlly it is fault coustomer said.now i erase NOR then flash with hwk.also write eprom.problem still. Region: 1, 0x00000000-0x0000073F, Length: 1856 bytes Region: 2, 0x00004000-0x00006897, Length: 10392 bytes Region: 3, 0x00020000-0x00020003, Length: 4 bytes Region: 4, 0x00021000-0x006583C3, Length: 6517700 bytes 1st Boot Ok, McuId: 000603EE, Rom: 00004B45, 5-1.0 (Trident 2) 2nd Boot Ok, McuId: 000603EE, Rom: 00004B45, 2-1.1 Fll Boot Ok, Vers: 5.11, fl_sceptre3_nice_std_v24.sre Flash1: Fl_Id: 00B00000_008D0000 - Sharp LRS18CK Baud Rate Set: 460800 bps MCU File: C260BBGE1.s3 Flashing NOR part... Write Done, 6529992 byte(s), Time: 04:40 any idea pls share but phone not come in local mode see here Phone Must be with Battery and Powered On ! Failed to enter Test Mode Phone Must be with Battery and Powered On ! Failed to enter Test Mode |
same problem need help pls,,,,,,,,,, |
