05-13-2014, 21:50 | #1 (permalink) |
No Life Poster Join Date: Dec 2008
Member: 934255 Status: Offline Thanks Meter: 63 | I9305 i9300 very strange problem.. Change display imei null This is a very strange problem. I need to replace a display from a samsung i9305, so i bought a display and i assembly the board on it. after assembly the imei is null!!! When input the board on other display the imei is ok!!!! How is possible the display damage the imei??? When is imei is null i try to repair it on nspro without sucess. When i put the board again in other display the imei repair by himself... Very strange problem... |
05-21-2014, 18:18 | #2 (permalink) |
Insane Poster Join Date: Apr 2014 Location: Brampton, Ontario
Member: 2172444 Status: Offline Thanks Meter: 8 | Quite strange. my guess would be the chips on the lcd board dont like talking to the main board. which in case is causing communication problem between the boards. also did you buy a i9300 or a i747 assembly. because the frame is a little different on each. check and report. Thanks |
