I8320 show charging without charger i to all i have a Samsung I8320 , it has charging fault the mobile is showing charging it self without charger , i have change charging block and also check it without block but same problem , plz tell me how can i fix it thnx in advance |
full flash... and all ok be sure tested by me many times. |
i'm waiting result after full flash!!! :) |
hi plz tell me ho can i flash it , send me file and all tools link and and flashing procedure , i will be thankful to you |
type *#7284# select "USB Configuration" after select "USB-PDA Chip" then touch on "Select" and "Back" If self charging not stoped, then again type *#7284# select "UART Configuration" then select "UART-PDA Chip" then touch on "Select" and "Back" |
