I9000 : how to change emmc chip ? hello how to change I9000 emmc chip programming of eMMC required? |
or you can try solution to swap emms to microsd card/ you need to remove old emmc, after take 16g or 32g microsd class10 format and burn 2 partition in "GPARTED"-program/1-(2g-rfs) and second partition on fat 32. Put this card to phone -reflash 3 files firmware with pit. After flash Ceanogen rom -7.2 , and after that you need to repair setings on file system because the phone in default dont see internal SD. If you really want to do this solution( TESTED by ME and working perfect!!) I will write you step two - what you need to change in setings foraviable sdcard :cool: |
thank you Mr. genych customer is does not want the memory card I did mounting one eMMC but not work emmc I'il try different eMMC |
thanks ok my problem was resolved had original ******* I used Hynix http://l1304.hizliresim.com/18/c/lyy1g.jpg http://k1304.hizliresim.com/18/c/lyy2q.jpg http://l1304.hizliresim.com/18/c/lyy2w.jpg |
thanks |
1. remove old emmc 2.Take 16gb class 10 , put to PC , 3.Boot Gparted iso 4.create 2 partition /first-resrfs=2000mb/second fat32=rest of it 5.Put this sd card to phone and flash 3 files firmawe with pit file.Do factory wipe 6.Install Root to phone 7.Install this zip : https://hotfile.com/dl/211258401/ba111e3/ES.zip.html 8.Open ES_fileexplorer on phone,go to settings and check all "V" in root setings,Then go to main page of this program and tab on "UP"(folder icon). 9.Go to:system/ets and open "Voldstub" file (wit note) and now be acurate 10, change parameters to # internal sdcard: dev_mount sdcard1 /mnt/sdcard/external_sd 1 /devices/platform/mmci-omap-hs.1/mmc_host/mmc0 # externel sdcard dev_mount sdcard /mnt/sdcard 1 /devices/platform/mmci-omap-hs.0/mmc_host/mmc1 11.tab on back and back, save changes and reboot your phone. 12.Engoy and dont forget , this solution working for all originall firmwares. P.S for custum firmware another setings of voldstub file:cool: |
thanks! |
Hi, @gynich, @proton how do you remove the chip without damaging other components? I will with hot gun method? |
[QUOTE=genych;9337683]after change you need to flash 3 file wirmware with pit!!! or you can try solution to swap emms to microsd card/ Will this woork for i9300? |
best regard proton |
