Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 09-14-2013, 14:43   #1 (permalink)
UU2
Member: 21987
Thanks Meter: 27
i9100 battery temperature warm.
Can someone specific solution for this?
Just general things I found him....
"Disassemble the phone and disconnect the charging jack strip from the main board then insert battery and check .If still havin issue its an issue with the battery temperature detection . If phone powers on dial *#0228# and check batt temp could be around 35 deg cel .If its havin extreme variation must check VBAT line and BSI line for any damaged component..etc."
Old 09-14-2013, 16:24   #2 (permalink)
d-Artigo's Avatar
Member: 1573913
Sonork: hardware illustration
Thanks Meter: 7,443
samsung gt-i9100 battery temperature
only thank button
The Following User Says Thank You to d-Artigo For This Useful Post:
Old 09-15-2013, 09:47   #3 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Thanks I look at them!
The service menu is displayed.....so 80 degrees detects the battery.
...parts are stretched!
Old 09-15-2013, 17:06   #4 (permalink)
UU2
Member: 21987
Thanks Meter: 27
It is the fault of the resulting: transistors Q500 and Th401, R481, R482 water demage.
Transistors can be replaced and the rest could only demolition....however, not as impressive S2 Motherboards which these components are in the position!
This version where is located in the Th401, R481, R482?
Old 09-15-2013, 21:11   #5 (permalink)
UU2
Member: 21987
Thanks Meter: 27
One more question, if I remove these parts,/Th 401 ,R481.R482 Q500/what will happen?
He will not mistakenly detect the temperature or so there will be no charge?
Old 09-15-2013, 21:26   #6 (permalink)
UU2
Member: 21987
Thanks Meter: 27
Now I look at the drawing ....Q500 does not work for.
TH400=TH401?
R402,R403=R481,R482?
Old 09-16-2013, 06:52   #7 (permalink)
d-Artigo's Avatar
Member: 1573913
Thanks Meter: 7,443
TH400=TH401?
phone in the water .... = shorting
I asked:
1. mobile live but if in the charging icon goes and stops charging ..?
2. experience in mobile phone charging excessive heat
3. what about his shorting
please explain that another friend can also help
Old 09-17-2013, 21:44   #8 (permalink)
UU2
Member: 21987
Thanks Meter: 27
The symptom and the location where it was!
Th401 (R481,R482) defekt...water demage.
The question, but just to be replaced by the TH400, R402, R403 parts??
The answer is YES!!
The unit charging perfectly!
(Temp.:35C)
Thanks for the information!
Old 09-19-2013, 09:38   #9 (permalink)
LordMen007's Avatar
Member: 184793
Sonork: 100.1574609
Thanks Meter: 45
just change the battery this problem from battery
Old 09-19-2013, 13:30   #10 (permalink)
UU2
Member: 21987
Thanks Meter: 27
My dear friend, you can read or just look????
This error've been talking about here is not with the battery!
But, as we have derived and who repaired it...the TH401 and the R481-R482 defective parts!!!
And this error is the formation of water or just by itself ... must arise!
Because Murphy has been described as: what it can deteriorate has been accepted!
Old 09-19-2013, 16:52   #11 (permalink)
d-Artigo's Avatar
Member: 1573913
Thanks Meter: 7,443
samsung gt-i9100 S2 Q500 location
Old 09-22-2013, 08:10   #12 (permalink)
UU2
Member: 21987
Thanks Meter: 27
I do not understand why you did this come from?
This error does not resolve the exchange of Q500....but the TH401!
The Q500's fault that causes absolutely no charge....this is not discussed here.
Old 10-21-2014, 17:28   #13 (permalink)
Member: 2277057
reball or change ic u504
Old 08-12-2015, 14:44   #14 (permalink)
Crazy Poster
Member: 2065028
Sonork: 1669019
Thanks Meter: 4
Question
Any more solutions plz
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.28409 seconds with 8 queries
