I9100 Water Damaged. No WiFi no Bluetooth. IMEI and Serial number OK. Hi all. I have a Samsung Galaxy S2 I9100 after water damage. There is a problem with wifi and bluetooth - they don't work at all. I can enter menu but they won't activate. Is it a software issue? If hardware which part would it be? Thanks for any help Regards. |
Anybody could help me please? BR |
It's a hardware issue. 1. Disassemble the phone, 2. Remove all corrosion 3. Turn the Mboard over where you can see the battery thats soldered onto the board. 4. Check and see if the battery has burst and is leaking 5. All the components around the battery must now be checked for correct readings. 6. If the readings are not accurate then they must be replaced. 7. There are 5 resistors and 1 capacitor. 8. Re-assemble the phone and turn on BT and Wifi http://i1250.photobucket.com/albums/...psa5251ea6.jpg |
