10-09-2013, 06:35 | #34 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1985902 Status: Offline Thanks Meter: 0 | Hello, the problem I have, is that U501 in theory is a 3-pin mosfet as indicating the PMR280UN datasheet. Now, on the motherboard listed above, and mine, in the place of U501, there is a component that has 6 pins .... What component is this, if in fact mosfet U501 is a 3 pin? . There's something wrong. If someone can confirm, I'd appreciate. A greeting Pd.: I've seen that generally, what fails is U500, there are some videos online. Is it true?. Thanks in advance. |
11-10-2013, 10:01 | #35 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1115220 Status: Offline Thanks Meter: 1 | i9300 stop charging http://imageshack.us/a/img5/3033/vhj5.png |
12-13-2013, 12:06 | #36 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2083864 Status: Offline Thanks Meter: 0 | Hello. I have the same problem as other. I list my measures with connected pcb only by microusb without lcd etc.: C559 ~ 0V C561 ~ 0V C558 ~ 0V On C565 and C563 and U502 I have 5,1V, because that much is providing from usb port. On the left side U506 I have 5V, but on the bottom what is the out of charging(I think), i don't see any voltage :/ The place where should be 1,8V according to post from first page, I can't measure this because is to small for me. Does anybody can help me? Last edited by Movalis; 12-13-2013 at 12:15. |
12-15-2013, 16:32 | #37 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Quote:
12-18-2013, 12:45 | #38 (permalink) |
Member: 2083864 Status: Offline Thanks Meter: 0 | It turned out that I made a short circuit(USB port also was a problem). Unfortunately, I have too big solder and arrowhead and additionally probably I little overheated the port(that said guy in the service). I had to give the phone to the service (unfortunetly they are expensive). Finally they will change the usb port and cut the short circuit. Very thanks for an answer. Have a nice day. Last edited by Movalis; 12-18-2013 at 12:51. |
05-28-2014, 18:16 | #39 (permalink) | |
Junior Member Join Date: May 2005 Location: eskişehir türkiye Age: 43
Member: 144086 Status: Offline Thanks Meter: 2 | batterry icon then not charging.solution charg_i9300.jpg Quote:
12-30-2014, 05:35 | #43 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2319455 Status: Offline Thanks Meter: 0 | I have had my S3 for nearly two years. Earlier this year, I had this issue with it charging/not charging. I bought an aftermarket inductive charger and have had zero problems ever since. During the day, if the battery gets low, I put in on the charge stand. At night, I plug in the usb and it charges to 100% every single time. I bought a Samsung tablet and am having the exact same issue as I had with my Samsung phone. |
01-01-2015, 22:00 | #44 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Hi guys i have strange problem on my i9305 when i connect the charger in to the phone i get error saying no battery connect can some one tell me what to do? i already replaced new charging connection.already change new battery |
07-07-2015, 12:02 | #45 (permalink) |
Junior Member Join Date: Jul 2015 Location: Austria
Member: 2423775 Status: Offline Thanks Meter: 0 | Hello Folks can you pls verfy some parts for me in the sevice manual it seems that U500+U502 (MAX14607EWL+) is the same which seems not to be correct! On my phone I found: U500 = MAX77686 U502 = maybe a MAX14607EWL+ cannot read to small U506 = MAX77693 |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
